blown fuse/relay?
06-16-2009, 08:56 PM
on
blown fuse/relay?
I havent been able to get any answers on the other forums so i thought you guys might bring me up to speed. I was doing some electrical work and had the two wires coming out of the back up lights spliced open. And as i was doing something else i think they touched and when i came back none of the lights worked. So my guess is blown fuse/relay? correct?
06-16-2009, 10:51 PM
on
Sounds about right, check the owners manual it should show the location of the pesky fuse.
06-17-2009, 04:07 PM
on
Yupe that sure was the problem. Got it fixed. and while i was doing that added some extra back up lights and a CB while i was doing some electrical work any way.
06-17-2009, 10:32 PM
on
Good to hear it, If your going to do connections the best are soldered and shrink tubed. Crimped can give out on you when you need it the most.
06-17-2009, 11:32 PM
There are some crimp connectors that are real good (electricians use them) but they are spendy and require a crimp tool you cant pick up at Autozone or Knechts.........Best just to follow Kjvs advice and solder/shrink tube it.
Sugars Pop
1999 to 2016 Super Duty
02-20-2013 02:23 PM
jeeplj8
02-21-2012 03:08 AM
Heavy460
03-09-2008 11:20 AM
opnekryan
08-08-2003 06:42 PM
