Hello All,
just had my 04 Escape checked out at a mechanic and the computer said it was the egr valve. This started happening after I ran out of gas. The mechanic thinks that may have been part of the problem cause some junk may have made it past the fuel filter and gunked up the egr valve.
I would first check for vacuum leaks, then I would test or replace the IAC (idle air control), then if all checks out, do a compression test. All cylinders will have to be within 10 per cent of each other to have a steady idle. Note that the upper plastic intake will have to be removed to test the back bank.
thanx
celina
parking sensor
