rear diff
06-01-2009, 07:18 PM
on
rear diff
how do you determin what diff you have based on the tag?
06-01-2009, 07:39 PM
06-01-2009, 07:43 PM
on
both on a 2006 ranger sport dif tag says v 330 v then on bottom 10 88 5k10
06-01-2009, 08:51 PM
You have a 8.8 rear end.
But check the tag again. that 5k10 part can't be right. You don't have 5.10 gears...
06-01-2009, 09:30 PM
on
The 5K10 is the build date. The 330 should be the ratio but I do not believe they made a 3.30. Look at the Vehicle Cert Label on the door and under AXLE there should be 2 Numbers/Letters. If you tell me what they are I can tell you what it is. It is probably a 95, 96, or 97. 95=3.55, 96=3.73, and 97=4.10 and all are Non LS. R5, R6, and R7 are the same, only LS.
06-01-2009, 10:54 PM
on
its says 97 but whats the size 8.8 or 7.5
06-02-2009, 11:09 AM
Since they never put a 7.5 in anything after about 89 or 90, it's probably an 8.8.
06-02-2009, 11:43 PM
on
Quote:
Originally Posted by
limalimamikefoxtrot
8.8 . I should have said that but someone already said you had 8.8.
06-02-2009, 11:49 PM
on
5.0B2
Not true. On the 2005's code 86=3.73 Non LS 7.5", 87=4.10 Non LS 7.5", and F6=3.73 LS 7.5"
sbrodacz
Escape & Escape Hybrid
05-13-2013 11:15 PM
Deluxe06
31
12-17-2011 08:13 PM
Dirtrider0213
11-18-2009 12:26 PM
crack
07-03-2007 05:22 PM
motobub
03-22-2002 07:38 PM
75 ,
83 ,
88 ,
bronco ,
decoder ,
diagram ,
diff ,
end ,
ford ,
ls ,
numbers ,
ranger ,
rear ,
tag ,
v330v
