4R70W Oil Cooler Lines; Which is in and which is out??
I have a 2002 F150 FX4 with the 4R70W transmission; dual core radiator with the aux transmission cooler. My question is which port on the transmission goes to the radiator and which is the line from the aux cooler? Yanked the lines off and forgot to mark which one was which; I should know better.....
THANKS!
THANKS!
From; AODE and 4R70W Transmission FAQs - Baumann Electronic Controls, LLC
7. Which cooler line fitting on the AODE/4R70W transmission is out and which line is in?
On the AODE/4R70W transmission, fluid leaves the transmission through the lower case fitting, and returns from the cooler through the upper case fitting. Please note, this is NOT true for the AOD.
4byford
03-14-2017 08:01 AM
Mark Kovalsky
12-20-2015 10:28 PM
Jermafenser
10-01-2009 04:42 PM
Trigger200
1997 - 2003 F150
06-01-2009 11:14 AM
