June Bull$#*@ Thread
Hey Barry, yes I've been to cruising the coast once and we had a blast, we set up in a little park by the commercial boat harbor, tail gated and cooked and watched all the rides go by!! I think we may go to this one just to check it out
ok so i got a question for all of ya'll
i did a cam swap in my 77 w/ the 302 and the c4 got it all back together started it up relized trans line was leaking... lost maybe 2 quarts. got the line patched started the truck back up broke in the cam at bout 2k for 15 mins or so engine runs strong now. put the 3 qrts trans fluid in got about 1/2-3/4 qrt too much OPPS.got in it to go test drive and see the cam in action and my 3 speed trans will only go from 1st too 2nd and not shift into 3rd WHY? would to much trans fluid make it do this or did i fry my trans some how. shifted out fine when parked to do cam swap.
Next I would make sure the fluid is at proper operating level. If those pan out you prolly fried the tranny
Mark:
Try draining off some till you get the correct level. Fluid could be foamed up & not pumping right.
#30
Afternoon to all, been a while since I have been back on the forum been a busy summer already and haven't even got started. Changed the brakes on the SD last wknd..... Wow fun fun fun.... It was not bad except for leaving the E-Brake applied and trying to take the rear rotors off This doesnt work very well.. But once I figured out what I had done it was a piece of cake. Went ahead and changed both rotors and brakes front and rear and man what a difference...... Hope all are having a good and safe summer so far
