Towing w/ 4.2
The 4.2 is NOT a powerhouse,I personally love my 97 with the 4.2 automatic,but it does lack power under certain situations....My suggestion is to get a good quality Tranny cooler installed,and unless on a straight stretch keep it out of O/D.If it starts "hunting"...going between 3rd,and o/d..its having a hard time.......I am of course "assuming" that you have a automatic.........
BTW..If no one has made the statement.Let me be the first..Welcome to our world!
Mind telling us what kind of 7,000 lb trailer you're yankin'?
If you are towing an open or flatbed trailer, you shouldn't have too much of a problem. Hill starts will be extremely difficult, but once you get it moving, it should do okay. If you are considering an RV that big, I seriously urge you to reconsider. The 4.2 will not be able to maintain highway speeds with something that large, even up the slightest inclines. Wind resistance will be the killer here, and you'll likely spend most of your time at 45-50 MPH near redline in second gear. Not good for the engine, much worse for the transmission!
Frontal area often means more than trailer weight, until it comes to pulling hills. You're not likely to overheat the engine just from pulling, unless you are pulling long hills at high altitudes. I'd invest in a large tranny cooler if it were me.
Also, if your trailer has electric brakes you will need a brake controller. If it has surge brakes you won't need much of anything. Regardless, a trailer that size NEEDS BRAKES, so make sure your truck is equipped to use them!
Good luck!
Good luck!
Looking at an RV. 7K would be the absolute max. I'm shooting for one that is in the 4K range, but depends on what I find for the $$. In the past, I've towed a 8K# 20' enclosed trailer with a 4 runner with a 3.0L. (Flat was fine, struggled up the hills) I understand that up a grade of any significance it is going to be slow going, but I wanted to make sure it isn't going to damage anything as long as I keep an eye on the gagues. I am going to have to use what I have until I can get a more powerful tow truck. I've got a friend that is building an inline 6, 300ci for pulling a camper in that size range. It does have a little more ci, but the V-6's seem pretty bullet proof once the gasket issue was resolved.
I would not worry about an oil cooler. Ford has some of the best stock engine cooling systems if kept maintained properly. For a trans cooler, I recommend B&M coolers. They work extremely well, they have built in low temp bypass, and they are small enough to fit just about anywhere. I run one on my van, and going in OD up a 6% grade at 80 mph only gets the trans temp up to 150 on a '95 Aerostar. Get the largest cooler that is practical. B&M uses a stacked plate design that is rugged and damage resistant and I can vouch for them. got mine from summit.
