Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Minor problems with a '93 Lightning
Old 09-29-2000, 01:54 PM
dondrd's Avatar
dondrd
dondrd is offline
Hello, this site is a Godsend for me.
First - how do I get the cap off the turn signal lever. Wipers don't work as they should. I read somewhere a while back that a foam swab and contact cleaner could take care of this IF I could get the cap off without breaking it. Second- overdrive light on shift stalk is out-how do I change or repair that? Third- it's great to find this site. Lightnings are great trucks, new or old.
Other problem I have is I replaced plugs, cap rotor, wires all twice because since I did the engine surges at ~2200 rpm. What could I have goofed up? Firing order is right.
Did not mess with timing.
Have to change serpentine belt every 20-25000 miles, is that normal.
Suggestion-my radius arm bushing on the passenger side failed at 30k and it appears that heat from the converters is the cause, I att'd a pc of aluminum to the frame as a heat shield and it still looks like new. Also balljoints are gone 2 65k. Is that premature? Sorry for all the questions. I feel like a kid in a candy store.
Old 10-12-2000, 09:08 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
>is right.
Did you gap the plugs (just a guess)? Also, how long has it been surging (miles)?
Sometimes though its not unheard of. Depends entirely on how you drive it. Are you agreesive with it (who isn't with a Lightning!)?
Ken Payne
Ford Truck Enthusiasts Admin
Old 10-14-2000, 03:57 PM
dondrd's Avatar
dondrd
dondrd is offline
First a little background: I attended Lincoln Technical Institute for Automotive Technology, Raced a couple mopar 340s in the '70s, have worked as an equipment mechanic in fossil and nuclear power plants for a total of 20 years. Iam NOT being defensive about anything, just want you to understand what level of mechanical experience I have. I'm not a super auto mechanic but I know basics. Yes plugs are gapped as required by factory specs. I installed replacement cap, rotor, plugs, and wires twice. I just can't see where I caused a problem. Maybe it's just a problem that was going to happen anyway but just stuck its head up at that time.
Thanks for taking the time to reply.
Old 11-03-2000, 01:02 AM
echobunny2's Avatar
echobunny2
echobunny2 is offline
MAS96F150
08-12-2012 12:40 PM
Ralph2117
05-25-2011 06:20 AM
1994 F250: 351, C6
04-18-2008 02:56 AM
blackmax
09-24-2004 07:08 AM
WV_351Lightning
11-26-2001 01:42 AM
Quick Reply: Minor problems with a '93 Lightning
