Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Saleen 5.4 3v Supercharger Compatibility
Old 05-20-2009, 03:17 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
For those that know me, I used to have this
a 2006 F-150 with Non-Intercooled RoushCharger. If we haven't met yet, Howdy
I have since sold that truck and now own a 2008 Expy EL with 5.4 3v. Frankly, I miss the power. I've contemplated using another Roush setup, but the more I read about the Saleen, the more it appeals to me...that, and Roush has been very very uncooperative with me in the past
So I've been researching my options for something similar. I found a Saleen Supercharger Kit for the 2007-2008 Expy. But...
Saleen pulled it from the shelves due to issues with the CARB certs.
They refuse to sell it until they can get the CARB cert done...I could care less about it. I'll never live there, so it's a non-issue in my eyes.
The Expy kit is detuned for only 400 crank HP (4 psi) vice the normal 445 crank HP
I am wanting to explore the possibility of buying a 04-08 F-150 Saleen Supercharger setup, and installing that into my Expy.
I know that I'll need custom tuning, but as far as I know, it should be a direct bolt-up and easy install...and I'd be running 6-8 psi...not a measely 4 psi
Anybody have any thoughts?
or would my money be better spent on just some regular custom tuning + 4.30 gears?
this is the "Family Car", so I cannot go very wild...but I want more
Old 05-20-2009, 03:22 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
btw, forgot that the MAF is in a different place than the 04-08 5.4
the MAF is down by the Driver headlight...so that would be an issue
Old 05-20-2009, 10:09 PM
Raider50's Avatar
Raider50
Raider50 is offline
is the MAF different on the kits or is it different from the factory? But either way with a little presidential engineering it should be easy to make it work witch ever way it is. But i would go with the f150 kit, or at least get the expy one change the pullys and get a new tune.
Old 06-07-2009, 08:56 PM
nagles '06's Avatar
nagles '06
nagles '06 is offline
tylus, I've read a lot of your submits here, unfortunately I can't help you with your question, but I could use some advise, it seems we are sort of searching for the same thing, I have an '06 scab 4x4 5.4, $2400 for non intercooled is real tempting, but maybe the whipple, or saleen, I drive about 50K per year, does a s/c not make sense for me, you wrote something about heat buildup
Old 06-07-2009, 10:46 PM
Raider50's Avatar
Raider50
Raider50 is offline
well im not tylus obviously, but I have a 115k miles on my non-intercooled roush charged 05. From my own experiences I would go with roush again, and i have had 0 problems with it. Well the oil changers caused me some problems but still even after driving about 200miles with 2x the normal operating oil it is still running strong as it was at 20k. Im not sure if that helped or not lol
Old 06-08-2009, 04:40 PM
nagles '06's Avatar
nagles '06
yes, it all helps, do you mean your guy put in 14 quarts of oil
Old 06-08-2009, 05:03 PM
Raider50's Avatar
Raider50
Raider50 is offline
yep, he did. I couldnt belive it even held that much. At the oil place they didnt drain any they just added to it.
Old 06-08-2009, 05:44 PM
nagles '06's Avatar
nagles '06
yikes, not to change the subject but do you remember changing out the spark plugs when adding the non intercooled s/c
Old 06-08-2009, 05:53 PM
Raider50's Avatar
Raider50
Raider50 is offline
they got changed out, but i had the ford dealership do the install so i could keep my warranty.
Old 06-09-2009, 03:53 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
see you're other thread in the 04-08 Forum. I completely forgot about something...and the heat you're asking about has made me remember it
Tylus
2004 - 2008 F150
74
10-25-2019 02:18 AM
Tylus
05-18-2018 10:42 AM
Tylus
11-24-2017 05:47 PM
Tylus
Ford Truck Parts for Sale
03-31-2016 04:03 AM
stangDiesel
Vehicles for Sale
02-01-2016 09:08 PM
Quick Reply: Saleen 5.4 3v Supercharger Compatibility
