Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-31-2009, 01:43 PM
jbkm jbkm is offline
jbkm is starting off with a positive reputation.
2006 Escape interior noise
I have a 2006 escape and its extremely creaky inside. Always making noise over bumps and such. Im thinking its a loose pannel or something rubbing together. Seems to be comeing from around the rear drierside door.
Any known areas to look for? Something simple to tighten down?
Thanks
  #2 (permalink)
Old 06-25-2009, 06:25 PM
smileyp smileyp is offline
smileyp is starting off with a positive reputation.
Same problem
Hello, i too have a 2006 escape and i am experiencing the same problems with the creaking, especially when going over uneven surfaces or even bumps. my sound seems to be coming from the rear hatch area. I had to tighten one of the brackets that goes through the rear glass and the gasket is completly worn out, wonder if that might be rubbing on the glass and causing that problem, wish someone would chime, im sure there are escape owners out there with the same noise.
hope to hear from someone soon, Phil
  #3 (permalink)
Old 06-25-2009, 11:06 PM
tcesni tcesni is offline
tcesni is new and has a neutral reputation at this point.
The rear hatch was a problem area on early Escapes so I'm surprised you are having problems on your 06. You might try wrapping the "latch" piece on the floor with some electrical tape and see if it makes a difference. I did it on my 02 and it made a difference.
  #4 (permalink)
Old 06-28-2009, 01:08 PM
Jonas1022's Avatar
Jonas1022 Jonas1022 is offline
Jonas1022 is starting off with a positive reputation.
Check out http://www.escape-city.com. Maybe some help can be found there. One of the members is a Ford tech. and has the TSBs, schematics, etc. Usually if you post up your problem, he will do some research to see if there are any similar issues, and a solution to help out the membership.
__________________
1994 Ford F-150 XL
2000 Escort ZX2 Sport (deceased)
2001 Mustang Bullitt GT
2002 Chrysler PT Cruiser
2008 Mazda Tribute iSport
Tags
creaky , escape , ford , noise , sound
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
