Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-31-2009, 01:41 PM
jbkm jbkm is offline
jbkm is starting off with a positive reputation.
Sticky Throttle
I purchased a 2006 Ford Escape 2.3 Auto about 8 months ago. The vehicle has 21K miles on it and its pretty mint.
Recently i've been running into an issues where if i get on teh accelerator pretty good and then let off the engine will continue accelerating for about half a second or so, then it will kinda jerk around a bit and level out. Doesn't sound like much but its VERY annoying and feels unsafe at times.
Ideas? I have an extended warannty but didn't want to go into the dealership sounding as if i had NO clue what to expect.
Also the vehcile is only averaging about 20-22 MPG mixed conditions, less than impressed because i got the 4 banger to save on fuel...
Shoulda just gotten an explorer sport trac or F150 or something...
  #2 (permalink)
Old 06-06-2009, 01:16 AM
oracle oracle is offline
oracle is starting off with a positive reputation.
There is a recall about sitcky throttle.. Maybe you need to check with any ford dealership if they can check if it's been done..
  #3 (permalink)
Old 06-06-2009, 08:34 AM
tcesni tcesni is online now
tcesni is new and has a neutral reputation at this point.
Maybe your 20-22 mpg has something to do with getting on the throttle so hard. But seriously, there was a recall for throttle cables in early models but I don't know of it includes '06. When you get off the pedal does the car want to accelerate for that extra second? That would be disconcerting. As for mpg, you are doing a lot better than you would with a Sport-Trac or F150 but we always want more.
  #4 (permalink)
Old 06-08-2009, 12:11 AM
sfcwoodret sfcwoodret is offline
sfcwoodret is starting off with a positive reputation.
Have it placed on the computer at the dealer since the warranty should still be in place. It will be able to check the throttle body.
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #5 (permalink)
Old 06-15-2009, 02:05 PM
kettle-one kettle-one is offline
kettle-one is starting off with a positive reputation.
My wife's 07 was sticking going on throttle. A new air cleaner helped a ton. Her's is a 5 speed and she gets about 20-21 mpg around town. Check for vacuum leaks in the intake track.
__________________
2007 Escape 4x4 2.3l 5 speed
2002 WRB WRX Wagon stage 2
1979 F-150 SWB 4x4 coming soon Alum SCJ 460/ZF5
1969 Dart GTS 340/4 speed AKA "the money pit"
  #6 (permalink)
Old 06-15-2009, 03:57 PM
Seattlewest Seattlewest is offline
Seattlewest is starting off with a positive reputation.
Sticking Accelerator
The accelerator pedal on my 2005 Escape has been sticking since I purchased the vehical from the showroom floor. The problem was that it took considerable pressure to to get the pedal to move from the idle positon. When the pedal finally did move, the excessive force caused the engine to accelerate more than needed. I found this to be dangerous while driving in traffic jambs. The throttle never stuck open. After two failed attempts by the dealer to repair the problem, I inspected the throttle cable and throttle body and discoved the throttle body spring was double wound or wound upon itself. I simply released and reset the spring and problem was solved.
  #7 (permalink)
Old 06-15-2009, 06:06 PM
^^ good to note, I've felt the same thing on my wifes 07, it since went away, but I'll check that.
__________________
  #8 (permalink)
Old 06-30-2009, 11:08 PM
Trublufords Trublufords is offline
Trublufords is starting off with a positive reputation.
Adjust idle stop JUST enough so STICKING pedal is gone,push throttle linkage with your hand while adjusting---does not take much of a turn.Cures sticking pedal on ALL MAKES. LOL Blue PS Fords fix under warranty was new throttle body,out of warranty Do as stated above. Got lots of LUNCH money doing this for customers!!!!
Tags
2005 , 2006 , 2007 , accelerator , body , escape , explorer , ford , pedal , sticking , sticky , throttle , xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
