F100 lug pattern.
Passenger cars wheels will not clear the calipers on 1980/83 F100's with 5 lug, 4.50" bolt pattern wheels.
Not all passenger cars have the 4.50" bolt pattern wheels, either.
1973/78 full sized Ford/Mercury's & 1973/79 Lincoln Town Cars/Marks are all 5 lug, 5.00"
Some 1973/Torino/Montego/Cougar/Thunderbird/LTD II/Ranchero wheels thru 1979 are 5 lug, 5.00"
Mustangs from 1974 thru at least 1992 are 4.25" / Only the SVO's are 5.50"
on
As a general rule, but not 100% definative... but what my service manual says...
Most of the 1980-1983 F-100's with 5x4.5 have power brakes. 10" brakes
Most of the 1980-1983 F-100's with 5x5.5 have manual brakes. 11" brakes
Also remember that adding a power brake system to one of these trucks is very simple.
on
Well geez,my truck gets weirder and weirder each day.As nflfreak43 stated,I've got the 5 on 5-1/2 bolt pattern.However,I have power brakes,which goes against what 81Explorer said.I know I was told that I have HD Brakes,but i'm not sure if that dictates whether I have power or manual brakes.
Here are the Brake Specifications to explain it further. The larger brake system wouldn't fit into the wheels of the 5x4.5.
From the 1981 Service specification manual... FPS 365-322-81
F-100 4600/4700 with Power Brakes
Minimum Rotor Thickness: 0.81"
Lining Area inner: 8.28"
Lining Area outer: 8.35"
Lining Thickness New: inner: .032"
Lining Thickness New: outer: .295"
Wear Limit: 0.030"
Caliper Piston Diameter: 2.597"
F-100: 4600/4700 with Manual Brakes/ F-100: 5000/5150 / F-150 / Bronco
Minimum Rotor Thickness: 1.12"
Lining Area inner: 6.99"
Lining Area outer: 9.55"
Lining Thickness New: inner: .0342"
Lining Thickness New: outer: .246"
Wear Limit: 0.030"
Caliper Piston Diameter: 2.875"
It doesn't really go against it, as there are exceptions as I stated.
Wear Limit: 0.030"
Wear Limit: 0.030"
Wear Limit: 0.030"
Wear Limit: 0.030"
Oh and would anybody know off hand whether or not a longbed is rare on F100's?Alot of the F100's I see are shortbeds.
on
some, but not all F-100s use the same identicle parts as the F-150. As far as GVWRs are concerned there is only 100Lbs difference between the Largest F-100 (5150) and the lightest F-150 (5250).
