Stihl FS55 trimmer wont start - Ford Truck Enthusiasts Forums
Old 05-30-2009, 05:04 PM
earnhardtracer38 earnhardtracer38 is offline
earnhardtracer38 is starting off with a positive reputation.
I have a Stihl FS55 trimmer that I am fixing for a friend. It wont start. The first thing I did was check for spark, it had none. I narrowed it down to the ignition module and replaced it. Still not starting. Then I took the carb apart and cleaned everything up with no luck there either. I put the carb on my personal FS55 that works and it worked fine, so that rules out a bad carb. I took the flywheel off to make sure the key was not sheared and it wasnt. So as of right now, I dont know where to look next. It has plenty of compression and the cylinder walls are smooth. What am I overlooking? I just noticed the primer bulb is cracked but I think that is just from me pushing on it a million times the past few days. Could that be the problem? Any help is appreciated.
Old 05-30-2009, 05:08 PM
I forgot to add that when I do try to start it up, it will backfire through the carb when it is on full choke.
Old 05-30-2009, 05:14 PM
Texas Outlaw's Avatar
Texas Outlaw Texas Outlaw is offline
Not a liberal...
Texas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant future
Have you put a new spark plug in? What type of plug does it have? Is it a resistor type of plug? If so, they have been known to look fine on the outside, but inside the little resistor assembly isn't fine and it can cause crazy backfiring. Went through this with a chainsaw about two hours after Hurricane Ike.
It sucked big time.
Old 05-31-2009, 01:23 PM
Yes, I have put in a new spark plug already with no help. It seems to be a timing problem but the key on the flywheel wasnt broken, so I am kind of confused. Every time I pull the plug after trying to start it, it is wet. So it is getting fuel, its just not igniting at the right time I guess.
Old 05-31-2009, 02:06 PM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Only thing I can add to the mix is check the muffler. There is a screen between exhaust port and muffler on a lot of trimmers that clogs up from burning oil and will screw them up big time. I've fixed 5 or 6 that were headed for the trash heap due to that simple thing.
Old 05-31-2009, 02:37 PM
hoosierbaby64's Avatar
hoosierbaby64 hoosierbaby64 is offline
hoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant futurehoosierbaby64 has a brilliant future
sure you didn't put brake fluid in it? /K ( I hope you know what this is reference to)
I was going to vote the fuel mix. But what do I know lol. I hope you get it fixed. I am suffering chain saw woes as well. will soon turn into withdrawls.
Old 05-31-2009, 02:50 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
I'd check the muffler like it was said, back firing out the carb could indicate the exhaust has no where to go
Old 05-31-2009, 03:29 PM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
put a lil gas in the cyl and pull it, see if it fires
Old 05-31-2009, 03:34 PM
150ford 150ford is offline
150ford is gaining momentum as a positive member of FTE.150ford is gaining momentum as a positive member of FTE.
Man I know what your going through. Hope you get her going.
Old 05-31-2009, 05:09 PM
No, I didnt put brake fluid in it, lol. I read that one too. The muffler isnt the problem either. I took the screen out of it earlier , it was clear too, and still nothing. I even tried starting it without a muffler, and still nothing. This one has me completely stumped. It is getting a good blue spark and it is getting gas, so it should at least fire up, right?
Tree Trimmer Dented my new Truck wh-7 1999 to 2016 Super Duty 14 08-04-2016 08:46 PM
Beard trimming: Good trimmer/outliner? Sterling Archer General NON-Automotive Conversation 0 08-29-2011 01:03 PM
Charger for 12v string trimmer websthes General NON-Automotive Conversation 5 06-26-2010 05:34 PM
Brush cutter blades on curved string trimmers? oldcoupe42 Garage & Workshop 6 06-28-2009 08:29 PM
Stihl or Husqvarna? tjay460 General NON-Automotive Conversation 57 03-25-2008 06:27 PM
Tags
55, backfire, backfires, fs, fs55, gas, muffler, plug, run, spark, start, stihl, trimmer, weedeater, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
