C6 for 351 cleveland
Old 04-22-2002, 07:49 PM
canadianfordman's Avatar
canadianfordman
canadianfordman is offline
I have a 351 cleveland and I want to bolt a C6 up to it. Is there a difference between small block C6's and big block C6's? I have a chance at a few but they were both previously bolted to big blocks. Thanks
Old 04-23-2002, 10:21 AM
dinosaurfan's Avatar
dinosaurfan
dinosaurfan is offline
CanadaMike, there are 3 differant cases that I have seen so far, first the FE case, the the 385 series case, and then the 6 cyl and small block. The internals are largely the same. I haven't seen a C6 behind a 351C in a factory application, but the local salvage yards here have lots of them behind 300 inline 6s, which would bolt to your 351C just fine. Look in full size 2wd trucks and vans. DF
Old 04-23-2002, 11:48 AM
Fordknut's Avatar
Fordknut
Fordknut is offline
I think all the 4Bbl Clevelands with ATs had C-6s mounted to them. I have a C-6 that was factory mated to a 2Bbl Cleveland in a Cougar; '72, I think. Small block C6s are somewhat scarce, but not what I'd call rare. Check out the local wrecking yards and attend a few swap meets; you should be able to find one. I'd sell mine, but I wouldn't want to go thru the hassle of shipping it.
Old 05-09-2002, 02:06 PM
DavidB's Avatar
DavidB
DavidB is offline
There are a lot of sb C6 trannys in salvage yards in vans behind I6 and sb V8 engines. Should not be hard to find one. I have seen many 70 Mustangs with 351C and FMX transmission. So many that I thought this was standard. I have replaced FMXs with sb C6s.
Old 05-09-2002, 04:35 PM
AZ4x4f150's Avatar
AZ4x4f150
AZ4x4f150 is offline
if you are running a 302 or a 351W the bell housings are the same.
If you are running a 351C or a 390 or 460 the bell housings are the same. you can not bolt the C-6 from the 302/351W to a 351C.
But you can interchange the insides from the big and small block C-6's
the torque converts will bolt up in either bell housing.
Old 05-10-2002, 08:36 AM
DavidB's Avatar
DavidB
DavidB is offline
"if you are running a 302 or a 351w the bell housings are the same.
If you are running a 351c or a 390 or 460 the bell housings are the same. you can not bolt the C-6 from the 302/351W to a 351c.
But you can interchange the insides from the big and small block C-6's the torque converts will bolt up in either bell housing."
I am having a little problem with the post from AZ4x4f150 above. There are so many different bolt patterns that I sometimes have to stop and think about which ones interchange myself. My recollection is this:
I6,289,302,351W, AND 351C interchange
332, 352, 360, 390, 410,428 interchange
351M, 400, 429, 460 interchange
These engine bolts patterns DO NOT interchange between groups.
I am getting on in years. My memory could be failing. You might want check with others for confirmation.
Old 05-10-2002, 09:19 AM
sauerf100s's Avatar
sauerf100s
sauerf100s is offline
DavidB, You are almost 100% correct. Some of the earliest 400's had the small block bolt pattern. A friend of mine told me he had one.
Old 05-10-2002, 05:44 PM
marriedguy1's Avatar
marriedguy1
marriedguy1 is offline
TMI
07-30-2017 03:17 AM
George Fletcher
25
10-02-2016 06:32 PM
olblue77
05-31-2016 04:43 AM
TMI
09-11-2015 05:56 PM
0351mike
06-29-2008 03:36 PM
Quick Reply: C6 for 351 cleveland
