Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-30-2009, 01:27 PM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Coolant system health
I was just re-reading a TSB and noticed the following:
Engine coolant quality can be affected by combustion gases, operation at low system pressure, or exposure to excessive system temperatures.
Engine coolant degradation characteristics include:
  • silicate drop out (clouding)
  • reduced corrosion protection
NOTE: Rust flakes and silicate that combine in the system might collect in the oil cooler and be mistaken as casting sand.
Seems like to me you either need a coolant filter OR you need to flush your coolant system any time you:
  • overheat
  • over pressure
  • under pressure (failed coolant reservoir cap)
  • possibly if you used the wrong coolant or used the wrong additive (additives are not needed w/ Motorcraft Gold Coolant)
  • allow combustion gasses to enter the coolant (EGR cooler OR headgasket failure)
  • use hard water for dilution
  • incorrect dilution
  • heavy commercial use that includes excessive idling or sustained high speed driving at excessive GVWR load
Recommend checking coolant anticorrosion strength. Check the anticorrosion strength (nitrite level) of the coolant using the Rotunda 3-Way HD Antifreeze Test Strip Kit part number 328-00001 , 1-800-Rotunda (768-8632) option 2
or equivalent. Perform coolant anticorrosion strength at the frequencies recommended.
NOTE:
FAILURE TO FOLLOW THE SERVICE PROCEDURE AS INDICATED CAN RESULT IN INACCURATE TEST RESULTS.
DO NOT COLLECT FROM THE COOLANT RECOVERY OR OVERFLOW SYSTEM. COOLANT MUST BE BETWEEN 50 °F AND 130 °F (10 °C 54 °C) WHEN TESTED. ROOM TEMPERATURE IS PREFERRED.
Start with clean, dry hands and utensils.
Collect coolant sample from the radiator or petcock.
Remove one strip from the bottle. Do not touch the pads on the end of the strip.
Discard strip if nitrite test pad has turned brown.
Dip strip in coolant sample for one second, remove, and shake strip briskly to remove excess liquid.
FOR BEST RESULTS FOLLOW TEST TIMES CAREFULLY. USE A STOPWATCH OR CLOCK WITH A SWEEP SECOND HAND.
Wait 45 seconds but no longer than 75 seconds after dipping strip to compare and record results in the following order:
(1) Compare FREEZEPOINT (end pad) to color chart on bottle and record result.
(2) Compare NITRITE (end pad closest to handle) test to color chart on bottle.
(3) The middle pad is for MOLYBDATE which is not a performance measurement used in determining maintenance requirements for these applications.
It is okay to estimate a value between color blocks, but if uncertain about the color match, pick the lower numbered block, for example if nitrite color is between F and E, use column E.
Coolant test results:
If the nitrite level exceeds 800 parts per million (PPM), no action is required, anticorrosion strength meets specification.
If the nitrite level is between 300 PPM and 800 PPM, anticorrosion strength is low. Add 32 fluid ounces of Motorcraft iesel Cooling System Additive.
If nitrite level is less than 300 PPM, anticorrosion strength is very low and cannot be restored refer to Step 6.
Flush the cooling system with Motorcraft Engine Cooling System Iron Cleaner and refill with 50/50 mix of Motorcraftâ Premium Gold Engine Coolant with Bittering Agent and distilled water. A 50/50 mix of the Motorcraft Premium Gold
Engine Coolant with Bittering Agent and distilled water provides the proper cooling system protection and nitrite level for operating temperatures to -34 °F (-36 °C).
CAUTION
DO NOT ADD MOTORCRAFT DIESEL COOLING SYSTEM ADDITIVE WHEN REFILLING THE COOLING SYSTEM AFTER A COOLING SYSTEM FLUSH WITH MOTORCRAFT ENGINE COOLING SYSTEM IRON CLEANER. THIS MAY LEAD TO
POSSIBLE ENGINE DAMAGE DUE TO VERY HIGH NITRITE LEVEL CONCENTRATIONS.
PART NUMBER PART NAME
VC-8 Motorcraft Diesel Cooling System Additive
VC-9 Motorcraft Engine Cooling System Iron Cleaner
VC-7-B Motorcraft Premium Gold Engine Coolant with Bittering Agent
9C3Z-8101-A Pressure Relief Cap
328-00001 Rotunda 3-Way HD Antifreeze Test
Strip Kit (1-800-Rotunda (768-8632)
Refill capacity is 27.5 quarts. Install a 50/50 mix. In extremely cold environments, never excede 60%. In hot climates still maintain 50%. NEVER drop below 40%. Service at 105k miles and then every 45k miles thereafter.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #2 (permalink)
Old 05-31-2009, 08:24 AM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident Smarta$$
2004 Ford F-250
D8chumley is gaining momentum as a positive member of FTE. D8chumley is gaining momentum as a positive member of FTE.
Mark, you continue to be "The MAN"!
__________________
'04 F250 KingRanch CC FX4 6.0 swb "BIG D"
Tim
GO FLYERS!
Originally Posted by hubler13f
When congress refuses to provide soldiers with the equipment to complete the mission. S.T.E.A.L. Sudden Transfer Of Equipment to an Alternate Location
  #3 (permalink)
Old 05-31-2009, 08:33 AM
ilo9's Avatar
ilo9 ilo9 is offline
ilo9 is starting off with a positive reputation.
So just to clarify if we are going with a 50/50 blend thats 13.5 quarts of coolant and 13.5 quarts of distilled water for 27 quarts total. or is it 27 quarts of coolant total
Scott
__________________
2004 6.0 KR F250
STOCK!!!!!!!!!!
  #4 (permalink)
Old 05-31-2009, 08:41 AM
bismic's Avatar
Quote:
Scott
13.75 quarts of coolant to be exact.
If you are flushing the system, Beachbumcook had a post on great procedure. It was several fills (4 or 5 IIRC) with distilled water, circulate, dump, repeat. After the dumping the distilled water from the last fill, add 13.75 quarts of Motorcraft Gold Coolant (or just go w/ 3.5 gallons to get close). Then just top off until full w/ distilled water.
Post #40 in the thread below is BBC's post on his procedure to flush your coolant system:
http://www.ford-trucks.com/forums/69...procedure.html
Be aware that the dealership will flush with tap water. In my opinion this is why the recommended change interval after the initial one is essentially cut in half. Flush the system yourself as described in the link - you will be better off than having the dealership do it.
__________________
Mark
  #5 (permalink)
Old 05-31-2009, 09:32 AM
bismic's Avatar
FYI Material:
There are 3 basic types of engine antifreeze:
IAT (Inorganic Acid Technology) - This is the original old style antifreeze, FMC used this up through 2002 MY trucks, 2003 MY cars, usually Green in color. Service life 36k miles.
OAT (Organic Acid Technology) - Silicate free, GM started using this in 1996 called "Dex Cool" usually orange/red color. Meets Cat EC-1 requirements. This is used by Audi, Jaguar, Porsche, Volkswagen, Land Rover & most Asian vehicles. Service life up to 150k miles.
HOAT (Hybrid Organic Acid Technology) - This is the newest antifreeze formula. It contains small amounts of Silicates to prolong aluminum component life and reduce cavitation wear of aluminum components. Ford started using this in 2003 MY trucks, 2004 MY cars (Ford "Gold" Coolant, WSS-M97B51-A1). This Coolant meets 'European G-05" specifiecations and is used by Ford, Chrysler, Mercedes, BMW & Volvo. Service life up to 100k miles.
Note: There is no such thing as "universal" antifreeze and color was never standardized, so do not use color alone to identify the antifreeze chemistry.
Ford standard - WSS-M97B51-A1 OR ASTM D 3306-00A
Compatible coolants for the Ford 6.0:
Ford "Gold" or Zerex G-05 or possibly Havoline Custom Made Antifreeze.
Info on Motorcraft coolants (five great links):
http://www.paulmachenry.com/documents/CoolantFAQs.pdf
http://www.fcsdchemicalsandlubricants.com/supplier/quickref/scuc.pdf
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1231104#Post1231104
http://www.ford-trucks.com/forums/807741-coolant-question.html
http://www.ford-trucks.com/forums/714726-what-am-i-missing.html
http://www.ford-trucks.com/articles/2003/5.php
__________________
Mark
  #6 (permalink)
Old 05-31-2009, 10:25 AM
juneau76's Avatar
juneau76 juneau76 is offline
2003 Ford F-250
My Garage
juneau76 is gaining momentum as a positive member of FTE.
Great info. Thanks Mark!!
__________________
Brad
2003 F-250 Lariat Supercab 4x4 6.0L PSD, Fumoto, Updated HFCM Plug, DieselSite Bypass Coolant Filter, 22" Wiper Blades, more to come...
2008 Taurus X Limited AWD w/ a Fumoto (The Wife's Family Truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #7 (permalink)
Old 05-31-2009, 11:32 AM
Dually TAS's Avatar
Dually TAS Dually TAS is offline
Dually TAS is starting off with a positive reputation.
Thanks Mark this was next on my list!
__________________
2005 F-350 Lariat DRW 6.0 PSD FX4 Tow Boss
  #8 (permalink)
Old 05-31-2009, 02:36 PM
Frankenbiker's Avatar
Frankenbiker Frankenbiker is offline
Frankenbiker has a good reputation on FTE. Frankenbiker has a good reputation on FTE. Frankenbiker has a good reputation on FTE.
Interesting, the way they refer to nitrate strength as "corrosion protection," and the levels to which they call "in spec".
In Class-8 rigs, nitrate strength is referenced to the ability of the coolant to resist cavitation erosion of the cylinder liners, which is QUITE different than normal "corrosion".
Additionally, 1200 ppm is the "add" level, with 2400 being the preferred level.
I wonder where the difference comes in?
-blaine
  #9 (permalink)
Old 05-31-2009, 11:30 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE.
Wow.. interesting TSB to read.
Thanks for the info.
(I had to post in order to get updates on this thread)
__________________
03 Excursion 6.0L PSD
Magnafine P/S Fluid Filter
Racor By-Pass Oil Filter System
Dieselsite Coolant Filter
Bilstein Shocks/Rancho Steering Stabilizer
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
  #10 (permalink)
Old 08-26-2009, 01:10 PM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future Kep4 has a brilliant future
I'm giving this thread a bump since cooling system maintenance is turning out to be of primary importance on a 6.0.
Thanks Mark!
Here is a link to the TSB that Mark posted and another TSB for cleaning the system after oil and/or fuel contamination:
http://www.fcsdchemicalsandlubricant...d/tsb/0985.pdf
http://www.fcsdchemicalsandlubricant.../tsb/08231.pdf
__________________
Russ
05 F250 Lariat CCSB 4X4 6.0 TorqShift manual T-case and hubs
Bilstein leveling coils/shocks, 35" Nitto A/Ts, ARB lockers, ARP studs, MBRP cat-back, Reunel front bumper, Warn 12K winch, coolant filter, Ravelco & Lojack
Towing an 07 Weekend Warrior FSC2800
So Cal FTE Chapter - Join *HERE*
  #11 (permalink)
Old 08-26-2009, 02:43 PM
janton01 janton01 is offline
janton01 is starting off with a positive reputation.
What about an engine coolant system filter. I installed the Napa 4019 after having to replace the oil and egr cooler. The oil cooler was completely clogged with brownish grey sand. Anyone want to see a photo drop me an email and I will send you one of the cooler and junk in it. I put one of the marine inline fuel filters in the coolant return line from the filter so I could see the movement of the coolant. When first installed the coolant in the system was a little cloudy. Now a beautiful crystal clear golden color. System installed using the heater feed line and returning to the 3/8 line on the top corner of the radiator. Easy and effective.
  #12 (permalink)
Old 08-26-2009, 04:38 PM
Got Diesel?
Quote:
Great....
One of the most popular coolant filter set-ups is the one that is sold by dieselsite.com.
__________________
24" Wiper Blades
  #13 (permalink)
Old 08-26-2009, 11:16 PM
FordMan35's Avatar
FordMan35 FordMan35 is offline
FordMan35 is starting off with a positive reputation.
Again a lot of great advise. I think a coolant fillter is going to be one of my first mods.
Ed
  #14 (permalink)
Old 08-27-2009, 02:20 AM
Got Diesel?
Quote:
Ed
The photos that are shown in the 6.0L PSd section of the dieselsite.com website are ones I sent them after being so impressed with their system!!!!
The pictures are worth a 1,000 words and speak for themselves!!!
From day one, I have posted that a coolant filter should be everyone's first mod they put on their trucks... again... just look at what it removes from the inside of your motor!!!!!
After one gets the inside of their motor cleaned up, then you can start considering other mods... at least it will reduce many of the problems the 6.0L motor has with clogged EGR systems and the like.
Good luck,
__________________
24" Wiper Blades
  #15 (permalink)
Old 11-02-2009, 04:50 PM
03-6L-X 03-6L-X is offline
03-6L-X is starting off with a positive reputation.
Test Strips - Who's
Does it make a difference as to which manufacturer's you use?
Are the Penray TS-100 (50/btl) or TS102 (10/btl) just as good as the ones mentioned in previous posts?
Tags
antifreeze , cleaner , coolant , cooling , ford , iron , kit , motorcraft , purchase , radiator , rotunda , strip , strips , system , test , vc9
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
