Blown head gasket symptoms. - Ford Truck Enthusiasts Forums
Old 05-30-2009, 10:35 AM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
We have lots of new to me 6.0 owners that have asked about the dreaded blown HG.I will start s tread on the symptoms and similar issues that appear to be blown HGs.
First what it is and why it happens. The 6.0 more prone than a lot of motors to lift the heads because of the design of the motor(4 bolts per cylinder) and torque to yield head bolts(TTY). This is the reason that most that know the 6.0 will tell you not to run a tuner on a stock truck. There was also some issues in manufacture on early trucks. The robots were recalibrated to correct this at Fords request in the international manufacturing facilities. The odd thing is some early trucks still have stock bolts and gaskets without any issue.So it is hit and miss.
In the 6.0 unlike a gasser when the HG blows the coolant doesn't enter the combustion chamber on a running truck (18-1 compression)but it can enter the chamber with a in some cases once the motor stops running in small quantities.So if your truck is running and there is a plume of stinky sweet white smoke coming out the exhaust you have other issues (EGR cooler very likely). The 6.0 pressurizes the water jacket in the motor and that pressure is pushed out the degas tank with coolant in what is known as puking.
Puking a quantity of coolant out the coolant tank is not necessarily a blown HG as flash boiling of coolant in the EGR cooler can also cause puking. This can be caused by a restricted oil cooler or bad water pump. Though when the truck pukes a couple gallons of coolant it is most all ways blown HGs.
When the HG is blown the truck runs as normal and may not puke much or at all, until it is worked hard at that point it will puke until the load is off the motor.If a truck is run in these conditions it is only a matter of time until the problem becomes worse as the gasket lets more and more combustion gas in the water jacket.
I will leave this here until I have more time to type (I type and spell poorly),I gotta go to work. I hope this info will help others that are new to the 6.0 .Anyone that has more info to add Please do.
Old 05-30-2009, 12:03 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
<TABLE style="WIDTH: 468pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=624 x:str><COLGROUP><COL style="WIDTH: 468pt; mso-width-source: userset; mso-width-alt: 22820" width=624><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl28 height=17 width=624>Common Causes for loss of coolant</TD></TR><TR style="HEIGHT: 12.75pt; mso-height-source: userset" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>EGR Cooler leaking</TD></TR><TR style="HEIGHT: 12.75pt; mso-height-source: userset" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>EGR cooler hose leaking</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Oil Cooler plugged or leaking (which elevates oil temps AND prevents coolant flow to EGR cooler</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=17 width=624>http://dan.prxy.org/Truck/6L_bible_html/html/Page_074.html</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Blown Head Gaskets from stretched TTY bolts, most likely from excessive CP (cylinder pressure)</TD></TR><TR style="HEIGHT: 26.25pt; mso-height-source: userset" height=35><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 26.25pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=35 width=624>Bad degas bottle cap (if you are puking coolant, you should replace the degas bottle cap after fixing the root problem).</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Clogged Radiator (air side)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Thermostat</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Some suspect a collapsed radiator hose</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Coolant Temperature Sensor</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Injector cup</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Glow plug cup</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=17 width=624>Warped or cracked head</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl26 height=17 width=624>Water pump fins are split where they go around the shaft:</TD></TR><TR style="HEIGHT: 38.25pt" height=51><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 38.25pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl27 height=51 width=624>Problem: When they fail, they only spin for a while and when they get hot the spinning will slow down. An easy way to check for this problem is pull the hose off the degas bottle from the intake it should pump the same amount out hot or cold. This can make your engine puke if it is your problem.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl25 height=17 width=624>http://www.thedieselgarage.com/forums/showthread.php?t=68584&page=2</TD></TR><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: silver; WIDTH: 468pt; HEIGHT: 25.5pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=34 width=624>
Common Root Causes for failed head gaskets - overboost and high cylinder pressures or warped heads (early on there were some torquing and casting problems)
</TD></TR></TBODY></TABLE>
Note: the degas bottle cap (coolant reservoir cap) should be replaced if it's been puked through more than once.
Old 05-30-2009, 12:04 PM
bismic's Avatar
Common OVERBOOST Causes
1. IRREGULAR RESPONSE IN VGT
2. BIASED EBP SENSOR
3. IRREGULAR EXHAUST GAS RECIRCULATION
Old 05-30-2009, 12:10 PM
bismic's Avatar
<TABLE style="WIDTH: 479pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=638 x:str><COLGROUP><COL style="WIDTH: 479pt; mso-width-source: userset; mso-width-alt: 23332" width=638><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; WIDTH: 479pt; HEIGHT: 12.75pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid" class=xl24 height=17 width=638>Visual inspection chart for coolant loss and cooling system problems:
Mechanical
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Leaks or weeps at:</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl26 height=17>
  • Hoses
  • Tubes
  • Clamp joints
  • Gaskets
  • O-rings
</TD></TR><TR style="HEIGHT: 13.5pt; mso-height-source: userset" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 13.5pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl26 height=18>
  • Thermostat housing
  • Radiator
  • Pressure relief cap
  • Coolant pump
  • Heater core (wet floor or coolant odor in vehicle)
  • Coolant crossover manifold assembly
  • Oil cooler
  • Degas bottle
  • Cylinder block core plugs
  • Block heater
</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 13.5pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl26 height=18>
  • EGR cooler
  • EGR valve
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl27 height=17>
Cracked or damaged:
  • Hoses
  • Tubes
  • Hose clamps
  • Radiator
  • Cooling fan
  • Fan clutch
  • Coolant pump
  • Degas bottle
  • Oil cooler
  • Block heater
  • Exhaust Gas Recirculation (EGR) cooler
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl28 height=17>
  • EGR valve
Restricted airflow through the A/C condenser/radiator
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Drive belt loose, worn or installed incorrectly</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Broken or weak drive belt tensioner</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Excessive white or light gray exhaust smoke (may have burnt coolant odor)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Coolant in engine oil</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Engine oil in coolant</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Coolant in automatic transmission fluid (if equipped)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Automatic transmission fluid (if equipped) in coolant</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 13.5pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl29 height=18>Fuel in coolant</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 479pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=638 x:str><COLGROUP><COL style="WIDTH: 479pt; mso-width-source: userset; mso-width-alt: 23332" width=638><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; WIDTH: 479pt; HEIGHT: 12.75pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid" class=xl26 height=17 width=638>
Electrical:
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl24 height=17>
Inoperative or damaged:
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Electronically actuated fan clutch</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Electronically actuated fan clutch controller</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Wiring, connectors, relays or modules</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Engine Coolant Temperature (ECT) sensor (if equipped)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Cylinder Head Temperature (CHT) sensor (if equipped)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Intake Air Temperature (IAT) sensor (if equipped)</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 12.75pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=17>Mass Air Flow (MAF) sensor</TD></TR><TR style="HEIGHT: 13.5pt" height=18><TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: yellow; HEIGHT: 13.5pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: windowtext 1pt solid" class=xl27 height=18>Vehicle Speed Sensor (VSS)</TD></TR></TBODY></TABLE>
Old 05-30-2009, 01:05 PM
bismic's Avatar
Here is a good troubleshooting chart for coolant loss:
http://www.ford-trucks.com/forums/pi...pictureid=8369
Old 05-30-2009, 01:30 PM
dcaddi2's Avatar
dcaddi2 dcaddi2 is offline
dcaddi2 is gaining momentum as a positive member of FTE.dcaddi2 is gaining momentum as a positive member of FTE.
Big High Five for both of you Brickie and Bismic as always. I'd rep you both, but I gotta spread the love some.
Not much to add to it guys, just an opinion.
If you do have a blown HG, sooner or later you going to have to get your vehicle fixed. Do not hesitate to spend the extra $ to get the ARP head studs installed. Some sources - ebay - advertise, sell "upgraded" head bolts. Stay away from it, they are the same TTY bolts as the ones that let your head lift. Even though the installation could be as perfect as possible, but the insurance to NOT have anymore HG issues are he ARP studs. Well worth the money.
- by the way I'm not a rep for Automotive Racing Products, just a really satisfied truck owner with studs installed-
Old 01-16-2011, 11:43 AM
dugoutdoug dugoutdoug is offline
dugoutdoug is starting off with a positive reputation.
I have a 2005 6.0L with 96700 miles- it is at dealer shop now with Blown head gaskets-my question is this--On DEC.8 2010 I took truck to dealer for service- oilchange-I told the shop foreman about a small oil leak,he told me after the oil change that he put some Dye inthe oil and to drive it a while -bring it back he would check for leak- I drove it for about a week then it begin giving me trouble- Do you think the Dye could have plugged the oil cooler and started this problem? Thanks
Old 01-16-2011, 12:02 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Quote:
Absolutely not. It's not the oil section of the oil cooler that gets plugged, it's the coolant section. Do a little searching and you'll find hours of reading on oil cooler replacement/failure
Old 01-19-2011, 08:01 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
I always thought you would notice a loss of power when the headgaskets were blown. If theres no noticable symptoms when driving, then couldnt someone be driving around on blown HGs for miles without even knowing it?
Old 01-19-2011, 08:08 PM
bismic's Avatar
IMO - yes.
Old 04-26-2012, 11:21 PM
memarkers memarkers is offline
memarkers is starting off with a positive reputation.
I was told by a dealer that my hgs are blown. The only problem I am having with the truck is the fan clutch is kicking on and off for no reason. At highway speeds the temp gauge goes fairly high then comes back down. No loss of power, no puking, no coolant loss and no white smoke or any smoke from the tailpipe. I changed the fan clutch thinking it was bad like it has before. I replaced the ect sensor. It did not help. I replaced the oil cooler and did the egr delete myself about 20K miles ago. Been running good. Just about had with the old beech. Anyone have any suggestions? How about a good independent mechanic in Dallas? Someone please help me before this thing becomes a freshwater reef!
Old 04-27-2012, 04:09 AM
bismic's Avatar
Old 07-27-2012, 10:19 PM
KingRanch2004 KingRanch2004 is offline
KingRanch2004 is starting off with a positive reputation.
Bismic, I was driving my truck today pulling a 8,000lb camper with ease. My temps stayed down and it ran fine. When ingot out of the truck I smelled a strong odor of antifreeze and found a couple drops on top of the cold air intake box. I could not find any leaks and nothing was dripping. I just had ARP head studs put on. I had black onyx gaskets installed at a the recommendation of the dealer where I purchased all of the other parts. The mechanics cleaned all surfaces and did a goof job with it. Any idea what's going on? I can't imagine having a blown head gasket already!
Old 07-27-2012, 10:25 PM
bismic's Avatar
I am sure you have already read threads on BO head gaskets, so I won't go there.
As posted earlier, there are any number of places for coolant leaks - hoses, degas cap, degas reservoir, water pump, radiator, heater core, etc. Try to rule each one out methodically.
If you are worried about head gaskets, I would follow the thread I wrote on troubleshooting the issue (link posted earlier). It was written to follow the TSB pretty closely in the important areas.
Old 07-29-2012, 07:37 AM
Well, after replacing the head gaskets with BLACK ONYX head gaskets (dealer recommendation) I pulled for the first time with a tow tune and blew a head gasket. I am pissed, I just spent a ton of money on this engine and these gaskets don't even have 300 miles on them AND I am running ARP studs!! I am not running the truck hard at all either. So, now that I am stuck with a truck with blown head gaskets, what do I replace them with THAT WON'T BLOW? I am tired of this truck being a money pit!!!!!!!
Can bad fan clutch cause overheating and puking or? dwdranch 6.0L Power Stroke Diesel 14 01-21-2017 04:05 PM
I'm guessing head gaskets? tfunk88 6.0L Power Stroke Diesel 21 04-25-2016 03:47 PM
You won't believe this! DSMMH 6.0L Power Stroke Diesel 5 08-25-2014 08:18 AM
egr or head gaskets? BRay09 6.0L Power Stroke Diesel 1 09-12-2012 02:30 PM
Puking/EGR delete pipe questions? red_georgia 6.0L Power Stroke Diesel 4 08-27-2007 01:51 PM
Tags
08, 1997, 60, blown, bottle, cap, degas, diesel, f150, f250, ford, gasket, head, powerstroke, studs, symptoms
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
