7.5/460 EFI throttle stciks when hot
I assume that it's injected... if it's a sticking throttle in the throttle body - Engine OFF - Remove the air intake tube to the throttle body and clean the inside of the throttle body where the throttle butterfly touches (or almost touches). Do this by spraying Carb Cleaner onto a rag, holding the throttle wide open (i did mention engine off...) and then wiping around the inside of the TB. Don't spray the Carb Clean directly into the TB as it can swell orings and seals. Make sure that there is no debris on the edge of the throttle butterfly as well. Put her back together and let her idle with no load (A/Con or electrical) for a few minutes to relearn the idle setting and you should be good to go. if it ain't it's the cable as per Lead Head...
Good Luck
Kiwi
Good Luck
Kiwi
Hopsing69
17
07-18-2013 05:39 PM
82 F150
07-28-2011 10:30 AM
murrhee
06-07-2009 07:41 PM
65f100CoryE.
17
12-11-2003 05:43 PM
Pauliewog
09-16-2003 09:34 AM
