Changing Oil Have A????
I am going to be doing the first oil change since i got my Diesel. It has 160k oil it. What oil should i use? I dont wan to go to a synthetic. I was at an auto parts store yesterday and they recommended somthing other than Rotella. Should i jsut use rottela or will any other oil work? Please help i will be doing this tonight and towing with the truck this weekend.
What oil did they try to sell you? The important thing is to make sure it's a diesel engine oil with the proper rating. You do not need to (or want to) put any additives in the oil. You'll need to buy 4 gallons of oil. The truck holds 15 qts.
I've used Rotella, Delo, Mobil Delvac & Valvoline premium blue in my truck. All diesel rated 15w-40 oils. All of them have done well for me. The important thing is changing your oil at the proper interval.
That's when I was draining Delo 15w-40 out of the truck and forgot to take the oil sample for Blackstone at around 270k. I dumped Rotella in at your place and then did Delo again on the next oil change so I could send a sample to Blackstone. The frustrating part is we had talked about me collecting a sample during the change.
I'm coming up on 293,000 now.
My truck has 196,000 miles on it,I have put 6,000 miles on the last Rotella Synthetic oil,and you can still read the dipstick through the oil...you can go alot farther on synthetic oil to counter the higher cost,but I guess you have your reasons for not going with synthetic,just my .02 worth
Phil
EDIT:Oh yeah I forgot to mention,4 gallons puts mine right at the sweet spot.
Phil
I went ahead and bought rotella form wal-mart 15w-40 it was $52 for 5 gallons. Also i used a motorcraft oiol filter. I hope the motorcraft filter is good? I just got done doing the oil and the oil filter that was on there sure was hard to take off. I have to use a screw driver. Anyway thanks for all the help guys i really appreciate it.
Motorcraft = Ford. Can't go wrong. Pretty much what we all use.
Change that fuel filter while you're in there, since the truck is new to you and you may not be sure of the last time it was changed.
