You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
We are working on processing about 65 gals a wk. Attached is a pic of the Magnesol filtering setup. It works, but there's got to be a better way . The "tower" has 3 4" diameter bags inside each other. 10-5-1 micron. The pump in the barrel is set about 4 inches off the bottom of the barrell, so most of the bio pulled is very clear already. It gravity feeds through the filters, then siphons into 6 gallon containers.
Heard some of you use diaphram pumps to pull bio through the filters.
__________________ Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!! 2002 TDI New Beetle - also likes Bio.
