Hauling a canoe
I don't have a receiver hitch.
I'm thinking to get a rack made out of square tubing that sits in the post holes in the corners of the bed walls. One in the front and one in the rear, like for hauling ladders. The rack's cross beam would be above the hieght of the cab.....but that's a pretty tall lift to hoist the canoe up there.
Most states only allow 3 to 4 feet of over hang with a red flag attached. Anything longer needs marker lights. Then you run the risk of someone rear ending the canoe because they have poor depth perception with a long narrow object.
I would recommend a ladder type rack. Safer and you will be able to securely tie it down.
One of our truck drivers got into a 5 car pileup a couple of years ago on I81 because a canoe come off a car.
When you think you have enough tie downs, add one more. (old flat bedder rule of thumb).
I have a 15' Jon boat and I will only carry it on the bed of my truck the 400yds I need to get it to the water. This bed is too short for an object that long. You are going to need some sort of roof rack to transport it any real distance. As an old truckdriver, if it doesn't look right... then it ain't.
