Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-28-2009, 06:57 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
Garage is empty, add now
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
Sodium or potassium hydroxide and your take on them.
I just recently went back to using sodium hydroxide instead of potassium because I feel as though I got a better reaction in a shorter period of time with it. this being said I wanted to know what you guys use and what you have found to be the pros and cons of each. with potassium I continually got a incomplete reaction at a base of 9 grams per litre and with sodium I get a good full reaction at a 5 gram base. What gives
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
  #2 (permalink)
Old 05-28-2009, 07:11 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
I don't have a clue why your having problems with KOH, unless it's drawing moisture...............
I'll never go back to NaOH because of the problems with handling the glycerol. I recover the Methanol from my glycerol, and it's thick enough after the Methanol is removed. If I used NaOH I'd have to heat it up to get it in my recovery system, then recover the Methanol, then deal with the rock hard glycerol. No thanks! NaOH glycerol is highly toxic to plants, and animals, so I'd have a major disposal problem.
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 05-28-2009, 07:21 PM
MAKO314's Avatar
the glyceren disposal isn't a problem here because I give it to a guy who uses it to mold fiberglass as a release or something, he says it works great. I don't know what the deal is with the potassium but with a 2 hour reaction time at 140* F I keep getting unreacted oil and soap
__________________
Ashley
  #4 (permalink)
Old 05-28-2009, 07:28 PM
1935 Ford pickup
It sure sounds like the KOH has absorbed some moisture. KOH is a lot more hygroscopic than NaOH. If it gets any moisture at all it turns into a chloride and will produce excess soap, and poor conversion.
__________________
  #5 (permalink)
Old 05-28-2009, 08:13 PM
MAKO314's Avatar
my lye comes in small 2lbs containers that are sealed. I dont open them untill I'm ready to use it, where would it absorb moisture? how do you store this stuff ? I'm open for any suggestions as I would rather use the potassium it's not as dangerous and is a little more forgiveing to small amounts of water and high ffa
__________________
Ashley
  #6 (permalink)
Old 05-28-2009, 08:20 PM
1935 Ford pickup
It could have been contaminated before you got it. I buy mine in 20 kilo bags (3 bags. one inside the other) and when I open one I put it in sealed 5 gallon pails. I had a bag once that must of had some moisture in it because I had the same porblems you are talking about. I opened a new bag and the problems went away.
__________________
  #7 (permalink)
Old 05-28-2009, 09:07 PM
MAKO314's Avatar
I'll give it another shot from another supplier and see. thanks Don.
__________________
Ashley
  #8 (permalink)
Old 05-29-2009, 08:24 AM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.
Just information.
I know this might sound nuts. But BE CAREFUL
I spent years working with Naoh on a professional basis. It is really dangerous in concentrate form. Please use the proper eye protection and NOT just safety glasses. Use goggles and a face shield at the minimum.
The shortest (at least in my professional research) of Naoh concentrate in contact with a human eye was 10 seconds which resulted in total blindness.
I just won't want you guys to underestimate the safety risk.
Never let your guard down with these caustic materials.
  #9 (permalink)
Old 05-29-2009, 11:14 PM
Fett Affen's Avatar
Fett Affen Fett Affen is offline
2004 Ford F-Super Duty
Fett Affen is starting off with a positive reputation.
When I started making bio, I decided not to use NaOH because of the solidification of the glycerine. I only had problems when I tried using less methanol in order to save money. I use the 2 stage method as I get better reactions with it and it is just a little bit more work. I store my bulk KOH in 5 gal Homer buckets and tranfer to smaller one gal containers with tight fitting lids.
  #10 (permalink)
Old 05-30-2009, 07:27 PM
Z-MAN's Avatar
Z-MAN Z-MAN is offline
Z-MAN is starting off with a positive reputation.
Koh, more forgiving on wet oil, and less soap production, disposal of the glycerin is much easier. only con is the current price jump.
i was paying 1.30/lbs, now 3.45/lbs.
i think yourt koh is less than up to snuff, some moisture in it, i use 8 as a base and almost always have complete conversion, only exception was very wet oil, not dewatered
__________________
2003 CC/SB SRW BLK 6.0 LARIAT FX4 4X4 SIX-GUN BUNDLE/W SPEED-LOADER, SCT3 W/SPARTAN TUNES,TRIPLE GAUGE A-PILLAR , PML TRANS PAN. ARP STUDS. GONE BIO, I.A.F.F. local #3970
2010 ESCAPE XLT 4X4
  #11 (permalink)
Old 06-10-2009, 08:32 AM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
kirkharrod has a good reputation on FTE.kirkharrod has a good reputation on FTE.
Glycerin with KOH can be composted. Glycerin with NaOH cannot.
__________________
2002 F-250 Super Cab, 289,000 miles, 89,000 on WVO; Greasecar conversion, 20 plate heat exchanger, AIH delete-water injection in its place, DIY stock fuel bowl delete, 6637 air filter w/ Pete's cover, Straight Piped, GPR LED mod, CAT ELC, 203* thermostat, Bosch auxiliary coolant pump, ext coolant filter, fumoto oil drain valve, Aeroforce Interceptor scan gauge, ISSPro trans temp, boost, EGT, elec fuel pressure gauges, Cyberdyne coolant, veg oil, ambient air temp gauges, 80W low beams/100W high beams. No major grease related problems.
Tags
hlydroxide, hydroxide, hygroscopic, more, potassium, potoassium, sodium, truckig
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
