You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Does anybody know if '99 SVT lightning rims fit a '93 Ford lightning? Or if there is a kit to change the bolt pattern on a '93 Lightning to a '99 lightning? Or if they make aftermarket '99 SVT Lightning rims to fit a '93 Lightnings?
Thanks
I am not exactly sure but I believe that they both used a
5-5/1\2 bolt pattern but the actual size of the rim might be different. you might want to call ford and see, but I believe it might work.
81 f-150 4x4 4in lift 351-w
33-12.50-15 bfg mudders
and a hole lot of KICKASS
I believe that Ford used the 5 x 5.5" lug pattern on their 1/2 ton trucks from 80-96. After 1997, their 1/2 ton trucks used a 5 x 135mm lug pattern. Why? I don't know... So odds are they wont work.
Hey, there is a company called AFS wheels, They make a replica lightning wheel to fit our 5 on 5.5 bolt pattern, they look exactly like the lightning wheels. Just goto www.afswheels.com. they cost only 850 for a set of four and measure 18x8.5 in size.
