Powertrain Warranty - Ford Truck Enthusiasts Forums
Powertrain Warranty
Old 05-28-2009, 03:53 AM
AAK625 AAK625 is offline
AAK625 is starting off with a positive reputation.
Question Powertrain Warranty
Hey guys, how are you? Isn't there a 100,000 mile Powertrain warranty on our trucks? What exactly does that cover? Is there some place I can find out? I couldn't locate it on the Owner site.
Thanks in advance,
Anthony
Old 05-28-2009, 04:24 AM
Tylus's Avatar
Tylus Tylus is online now
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
depends
did you buy it new, or used?
or did you buy it as a Certified Pre-Owned (CPO)?
if new or used, then you have a 3yr/36,000 bumper to bumper...and nothing else on your 2004 truck
that was the case from 2004 to about middle of 2006.
trucks built after July 2006 have a 3yr/36,000 bumper to bumper, and a 5yr/60,000 powertrain
if you bought your truck as CPO, then you have a longer powertrain. They just revised the term period on April 2, 2009...no idea what it was before that.
btw, thanks Crazy for pointing this out to me
Ford Certified Pre-Owned Vehicles
if you have a CPO, in some cases you have a better warranty than a new vehicle IMO...which is utter crap
Old 05-28-2009, 04:47 PM
Rikster-7700's Avatar
Rikster-7700 Rikster-7700 is online now
Rikster-7700 has a good reputation on FTE.Rikster-7700 has a good reputation on FTE.Rikster-7700 has a good reputation on FTE.
Quote:
Originally Posted by tylus View Post
depends
i think it came into effect April 2 2008, just to stop any confusion, other than that spot on, i am glad i bought my cpo now!
Old 05-28-2009, 07:07 PM
Does it cover clutch kits failing or differential issues?
Old 05-28-2009, 08:52 PM
Tylus's Avatar
good one...I'm gonna say "Ask the Dealer" for that
they are part of the Drivetrain, so I want to say yes...but we all know how weird Ford is about some stuff
Old 05-28-2009, 09:58 PM
isn't that what the internally lubricated parts thing is about?
Old 05-29-2009, 12:26 AM
Well, I'd have to ask a different dealer, because mine wants $1041 to replace the clutch kit they said was bad.
Old 05-29-2009, 03:21 AM
Tylus's Avatar
you might should escalate it to the Regional Parts guy. Explain the situation...especially how a clutch pack is part of the rear differential...which should be covered 100%
but you can pretty much be sure the Dealer has entered the issue into the OASIS network...if so, it means every Ford dealer is going to see what they've already diagnosed
Quote:
that phrase covers bearings, valve train...motor parts, and tranny bits
Old 05-30-2009, 08:29 AM
Is there a visual way I can confirm that these bloodsuckers actually looking inside the differential housing?
Old 05-30-2009, 07:10 PM
Tylus's Avatar
just look at the bolts
they all should have obvious signs of wrench marks, and the area behind the bolts should have fresh circular marks from the removal and installation
also, the fluid fill plug should be showing those same signs
Old 05-30-2009, 10:11 PM
Greg B Greg B is offline
Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.Greg B has a good reputation on FTE.
My 06 was an early build I bought used as a CPO and came with 6 year 75,000 mile powertrain warranty. I do believe that differentials are part of the powertrain warranty and as such the cluch packs should be covered. I can't say with certainty, but one would assume that would be covered under the all internal parts portion. It's possible that this dealer is balking at covering because they already have higher than normal warranty repairs or is under Ford scrutiny for shady practices. I'd definately see a different dealer. If that dealer takes care of you, that would be my dealer from that point on.
Old 05-31-2009, 04:16 PM
OK guys, I'll check it out and see another dealer. Thanks!
Can someone explain what falls under warranty? 06greenstroker 6.7L Power Stroke Diesel 5 11-25-2016 01:26 PM
F550 5k out of powertrain warranty need advice V10550 1999 to 2016 Super Duty 1 05-27-2015 04:57 PM
warranty for IWE system/auto hubs riverns 2004 - 2008 F150 10 01-23-2011 05:49 AM
2011 Powertrain Warranty? jh225 1999 to 2016 Super Duty 9 01-15-2011 03:07 PM
powertrain warranty? MRUGG 1999 to 2016 Super Duty 1 09-27-2010 02:25 PM
Tags
2004, 2008, drive, drivetrain, expedition, f150, ford, powertrain, train, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
