Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-28-2009, 03:34 AM
1950gmcelc's Avatar
1950gmcelc 1950gmcelc is offline
1950gmcelc is starting off with a positive reputation.
Egt & boost?
SO MY TRUCK IS STILL RUNNING RUFF AND I JUST INSTALLED MY GAUGES LAST NIGHT. MY ? IS WHAT IS NORMAL READINGS FOR BOOST AND EGT'S ON A STOCK TRUCK WITH A INTAKE AND CAT/MUFFLER DELETE. I KNOW I HAVE A FUEL LEAK FROM THE PUMP BUT I AM DUMPING ALOT OF SMOKE STILL. THE MOST I HAVE GOTTEN IS ABOUT 11 LBS AND 1100-1200 EGT'S DOES THIS SOUND NORMAL. I AM THINKING I MAY HAVE A TURBO PROBLEM BUT I'M NOT SURE. CAN YOU GUYS PLZ HELP[IMG]http://www.****************/forum/images/smilies/dunno.gif[/IMG]
[IMG]http://www.****************/forum/images/misc/progress.gif[/IMG]
__________________
95 F350 CREW CAB LONG BED 4X4 ZF5 SPEED
6637 FILTER HYPERTEC CHIP GUTTED CAT WARN WINCH AND BUMPER SOLID MASS CLUTCH CONVERSION 315X70R17
  #2 (permalink)
Old 05-28-2009, 07:48 AM
yoslick's Avatar
yoslick yoslick is offline
yoslick is starting off with a positive reputation.
My 96 with the mods in my sig can pull 20+ on the boost WOT, as for egt's most I have ever seen on mine was 1150 on a long haul up the blue ridge pkway out in WV.... Only time mine smokes is on chilly mornings after sitting all night and only lasts a minute or 2.....
Slick
__________________
96 F-250 Ext-cab 4x4 7.3 Long Bed
DIY Air filter (NAPA 6637)
3" DP,HPX,Gutless Kitty
14.6k Mod
DCC(SW/MTS) USN-Ret 75-95
  #3 (permalink)
Old 05-28-2009, 08:34 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is online now
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
Those boost numbers don't sound right. You should be getting around 18-20 pounds.
I'd pull the intake tubing off the turbo and check the wheel for play or extra oil build-up.
Or you might be having injector problems...
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), 14.7k mod, T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #4 (permalink)
Old 05-28-2009, 04:00 PM
1950gmcelc's Avatar
How can i check if i have a bad injector? I will check the wheel on the turbo but what else could cause my problems? Could a weak fuel pump be causing some problems as well?
__________________
  #5 (permalink)
Old 05-28-2009, 05:27 PM
1995 Ford F-350
My Garage
THere's a easy way to check your fuel pressure... can't remember where though. If it's a bit low you can shim the FPR and it'll boost it a bit.
__________________
  #6 (permalink)
Old 05-28-2009, 06:09 PM
etldak etldak is offline
1996 Ford F-250
My Garage
etldak is starting off with a positive reputation.
the boost stock at wot should be 15 psi. not info on egt
  #7 (permalink)
Old 05-28-2009, 11:24 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is starting off with a positive reputation.
I have found you can get a better boost reading if your under load. Grab ahold of your neighbor's 15k 5er and see what you have, lol.
__________________
Glenn
96 2WD F250 auto, 6637, 7 guages, two trans coolers, 3 1/2" DP-4" exhaust, FS2500 oil bypass filter, 1" turbo housing, rad filter, 6 position TW, 99 IC, syn oil, Elec fuel pump, adrenaline HPOP, 140v IDM, rear disks, Baby Beans Injectors, 203*, 'the cure', dieselsite's trans filter & air bags.
  #8 (permalink)
Old 07-04-2009, 03:21 AM
1950gmcelc's Avatar
pulling my 69 el camino in a 24 ft enclosed car hauler i was getting max 10lbs at 1250* and running out of power
__________________
  #9 (permalink)
Old 07-04-2009, 07:22 AM
79_250RangerLariat's Avatar
79_250RangerLariat 79_250RangerLariat is offline
79_250RangerLariat is starting off with a positive reputation.
Do you have a good connection on the map sensor line where you tied in the boost gauge? I had my little rubber connector go bad (fell apart less than a year old). Amazing the difference when the MAP sees full boost #'s, also a big difference on the gauge.
__________________
79 250 Ranger Lariat 429 4v, Duals, Built C-6, 4wd, B&W
97 250 Powerstroke Ex Cab, 4wd, 5 spd, 3.55, 6637, AIC, gauges, DP, 4" straight, B&W, air bags, ex brake, FPR, HPX, TW
96 350 Powerstroke 4x4 Dump, Luk SMF, 6637, 4", ex brake
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
