Burning brakes
Burning brakes
Today on my way to work (45min drive) I noticed my truck was running somewhat sluggish, it would vibrate like crazy, finally got it running somewhat better. Once I arrived at my place of employment , i noticed the smell of brakes burning, could not be mine, wrong about 45min later on my way home, the same issues, I decide to stop at my friends house enroute and at this point the Left rear driver side tire and rim was dang near hot enough to catch fire, all the others were alot cooler to the touch, jacked up the truck and let the brakes cool before removing lugs. come to find out the rear driver side caliper is either stuck or just gave out.as a check we bled the system, no luck, still wont spin freely, so tomorrow i am picking up a new caliper from autozone, oh yeah, the other side moves freely, so we know it's not the park break being stuck.
Maybe your right, We were thinking about the same thing, once we get the new part in and remove the old, we will investigate a little more, also I ha ve 9 day 4000 mile cross country trip in couple days, towing a trailer with a car, 3 kids, a wife and alot of crap, so i might just replace the entire thing, to include the slide pin, by the way how would i know if it's the slide pins?
oh yeah, when we tap on the caliper with a mallet, the drum will rotate, so what can that mean?
A funny side note:
I was following an older (96-98?) Taurus this afternoon, well, I was 2 cars behind her. There was some kind of smoke coming off the rear of the car almost like it was a coolant leak. I was trying to figure out what it was. I could tell from the smell as there wasn't any. Not at first anyways. I then smelled cooked brakes BIG time and the smoke was getting heavier from the left rear wheel well. We got to the next stop light and by then it was smoking pretty good. Enough that the driver had to have seen the puff of smoke go by her window and the smell, well, you know how bad brakes smell. She didn't stop. Drove about another .5 miles to the next light. It was red. Right before green, I pulled up next to her in the left hand turn lane and got her to roll down the window. It was a youngin driving (and talking on cell phone.) I told her that her brake where about to catch fire and that she needed to pull over NOW and call someone to come pick her up.
SHE HAD NO CLUE that there was anything wrong with her car. lol
Yeah, I was also curious as to what dlibson meant by the rear brakes on SuperDuty's are known to go bad... what part is the usual suspect?
I have a sticking right rear caliper and am unsure if it's the piston, the line or system needs flushed. The slide pins are free and I'm getting the system flushed this week (probably never been done so I figure it is time anyways)
Can you please define "went bad"? Was the piston jamming up or leaking or something along those lines? What did it look like?
The top piston as your looking down on the caliper would not for the love of.. retract at all, getting the caliper off took about 10 min to remove and some elbow grease. we did not see any obvious reason why it went bad, tried with c clam to push it in, the bottom piston retracted with no issues, but that top one would not, so we decided to remove it and replaced with new everything and double checked the new and all other calipers to ensure they worked, since i had less than 24 hrs to get on the road.
