Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-27-2009, 08:59 PM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 is gaining momentum as a positive member of FTE.
New Guy 74 Bronco
Howdy everybody!
I have been on FTE for a while over in the F350 area but I am picking up my "new" 74 bronco this weekend and wanted to introduce myself since I will be cruising around here too.
It's nothing to write home about but I am pretty excited to have something to build into a good DD and off-roader.
I hate to ask a real ******* question but I can't seem to find the answer anywhere. I see different broncos w/different rear fenders. Did all of those start off like mine and were just cut or was it part of a package from ford?
thanks
-Chris
__________________
Chris
M35A2 Deuce and-a-half
1996 F350 Crew-Cab 4x4 7.3 Powerstroke SRW
217K miles; 6in suspension lift; 33in BFG M/Ts; T3 "Get outta my way mod" w/warn 12K winch; WARN hubs; CB; Gauges; Herculined inside cab; 2008 Center console
  #2 (permalink)
Old 05-27-2009, 10:58 PM
McLeod's Avatar
McLeod McLeod is online now
McLeod is gaining momentum as a positive member of FTE.
They all started out as yours. It is called "uncut".
In order to get bigger tires and more flex the metal must be cut away.
Fiberglass flares are then rivited on to cover the cut edge. Some put flares on the front too.
"Uncut" Broncos are hard to find anymore, so depending on what you are doing with it and what condition the wheel areas are in, you may want to consider leaving your's intact.
Oh, and welcome to FTE.
We need to liven up this forum a little bit, so don't be afraid to post.
__________________
Just Say No!
'93 F 150 - 5.0, E4OD, 4.56, 33" & 4" Rancho lift
'95 Bronco - 5.8, E4OD, 3.55, 265/75 15 Goodyear Wrangler SilentArmor (excellent tire)
'67 Bronco Roadster, 351w, 4.11's, 5 inch Skyjacker lift
  #3 (permalink)
Old 05-27-2009, 11:42 PM
Thanks! I really enjoy FTE, there is a lot of know-how on here but this is my first time to venture into the bronco area.
After a little more searching I kept finding "uncut/cut" and I figured that was how it worked but just had to know for sure.
I have seen some SHARP looking rides that are cut but I am not sure if I am going to cut mine...I have seen some pretty good looking ones that are still uncut. I dont plan on turning it into some extreme-super-$$$$$-crawler-rig just something that looks sharp and can handle itself off-road.
Currently I am wheeling my 1-ton CC ford and I want something else to take a little of the wear and tear off her...hopefully i will be able to set her up like I want...all it takes is money
I wouldnt be suprised if I ended up very similar to this setup
__________________
Chris
  #4 (permalink)
Old 05-28-2009, 08:10 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
The red one looks like a mild 3.5" lift, and 33/9.50/15's. Nice combo for an uncut. Welcome to the madness. They are very addictive.
  #5 (permalink)
Old 05-28-2009, 09:57 PM
Quote:
WOW! good eye! that is exactly what it is: Ford : Bronco:eBay Motors (item 270397783780 end time May-31-09 16:32:15 PDT)
I cant say for sure it I am not going to cut it, but I seriously doubt I will if it looks that sharp...especially if uncut broncos are more difficult to locate
__________________
Chris
  #6 (permalink)
Old 05-30-2009, 04:40 PM
So I picked up the bronco today and it turns out its actually a 1969 model...not 1974.
Thats fine but I really had my heart set on the stronger front axle
Pics in a few mins
__________________
Chris
  #7 (permalink)
Old 05-30-2009, 05:10 PM
Pictures
__________________
Chris
  #8 (permalink)
Old 05-30-2009, 07:50 PM
McLeod's Avatar
Very nice.
Now get ready for lots of work and $$$$.
__________________
Just Say No!
  #9 (permalink)
Old 05-31-2009, 08:39 AM
gfw1985's Avatar
Actually, its in better shape than my first impression. You can swap out the front diff for a Dana 44 pretty cheap. Should be able to find one reasonable($500 or under) The whole running gear is cheaper to deal with than rust repair. Enjoy, and check out Classicbroncos.com Lot of Bronco specific info and members close to you for maybe some hands on help.
  #10 (permalink)
Old 05-31-2009, 09:14 AM
BarryMc's Avatar
BarryMc BarryMc is offline
2009 Ford F-150
BarryMc is gaining momentum as a positive member of FTE.
That's a nice looking Bronco and like McLeod said, get ready for lotsa work and $$$$
__________________
Barry
Mississippi chapter Ldr.
Join the Mississippi Chapter, HERE
2009 f150 XLT
1966 F100
1965 Mustang, 1978 Serro Scotty Camper
  #11 (permalink)
Old 05-31-2009, 11:21 AM
ksmith203's Avatar
ksmith203 ksmith203 is online now
ksmith203 is gaining momentum as a positive member of FTE.
Looks like a pretty good starting pioint to me. I can't wait to start mine.
__________________
1969 N600 wrecker on its way. Frame and drive train done...Waiting on cab from sandblaster.
  #12 (permalink)
Old 06-02-2009, 02:20 PM
mcdobson mcdobson is offline
mcdobson is starting off with a positive reputation.
Real nice starting point. It looks like it has the clasp that holds the spare tire rack to the side of the body. That's neat.
Don't worry about the Dana 30 front axle if it is going to be a DD. Just do the chevy disc brake swap to the 30 and when you do go to a 44 you can put the brakes on the 44.
Good luck and welcome. And yes classicbroncos.com as well es FTE.
  #13 (permalink)
Old 06-04-2009, 10:36 AM
thanks yall! I wont turn down free advice.. I will check out classicbroncos later this afternoon
__________________
Chris
  #14 (permalink)
Old 06-07-2009, 07:15 PM
mauicruza mauicruza is offline
mauicruza is starting off with a positive reputation.
If it has the original front diff then it should already be a dana44 with drums.
  #15 (permalink)
Old 06-08-2009, 12:38 PM
Up in one of the posts, it changed from a 74 to a 69. It should be a 30.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
