Well just got back from a 500 mile round trip on monday. Tuesday the truck ran fine, and now this morning it's not starting. I did this twice up on our trip but it fixed it self when you turn the key off and on. Any Ideas?
Thanks
Nick
__________________
Nick PAA#9
08 F-450 K R 6.4 SPARTINIZED, DPF/CAT GONE, RR Boots
04 X 6.0, 08 towing mirrors, 15k hitch, Firestone air bags
01 X 7.3, TN BB turbo, Dp tuner, ITP RR, RR up pipes, 4 Dipricol gauges,MBRP 4inch, 6637,650 dash with 2 auto meeter gauges, RR boots,
95 F-250 7.3, 6637
2004 model year the ICP was moved from under the turbo to the right front valve cover. Just want you to unplug it and the pressure reading will default.
The ICP (Injection Control Pressure) sensor needs to read 500 psig to fire the injectors. If it fails low, you will crank but not start. By unhooking it, your computer detects that it is not present and goes to a default control strategy that should allow your truck to start if the ICP sensor is truly what has failed. If you are having problems with your LPOP (low pressure oil pump) or HPOP (high pressure oil pump), disconnecting the ICP sensor will not make any difference.
Can you tell us more about your truck. Have you changed fuel filters recently? Does it have a strong crank but just not start? Are you sure your batteries are good? I always load test my batteries as the very first troubleshooting task when I have a no-start condition.
The second thing to check is to make sure you do not have loose fuel filter caps, cracked caps, or failed o-rings. Then make sure your secondary fuel filter bowl is filling up.
There are many things that can cause a no-start. Need more info to really troubleshoot, but you have a few easy things to check.
__________________ Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
The second thing to check is to make sure you do not have loose fuel filter caps, cracked caps, or failed o-rings. Then make sure your secondary fuel filer bowl is filling up.
Great post Bismic,I would rep you if I could.
__________________
Tony 03/04 6.0L 350 Crew ,DRW,ZF-6, XLT fx4, EconoMax injectors, Autometer Fuel, Boost & EGT. Fass 95/90, Sct X-III with some sweet Spartan tunes, ARP studs, RR fuel system, Southbend FB8, Fluiddamper, Ali Arc hunting bumper,Light Force, Ride-Rite helpers,Ford APCM and some other stuff.
03 6.0L Ex LTD mostly stock motor and a bunch of bolt ons on the truck.
No to be stupid but there are a lot of plugs in that area. Does any one have a pic of one?
__________________
Nick PAA#9
95 F-250 7.3, 6637
Try your local International dealer, the 6.0L engine is a VT365 IH or use Google search to find a deal from someone else like Ebay if you want to wait and have it shipped to your address. FTE Parts Guy
Sometimes spending $30 in fuel running between parts stores to save $5 doesn't seem rational.
Parts guy had em for $95 last year. Send him a PM.
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
