Carb spits gas out of the stacks?
We've been trying to get my brother's truck going forever. It was parked for a while (6 years). We got it to run and drive, but it ran rough and hesitated on acceleration. We came back in a week to work on it, and it would start, the idle would climb, then the engine would die. With very tricky feathering, we could keep it running sometimes, but it wouldn't stay running on it's own. It still hesitated when given gas, and then would die. We decided to rebuild the carb. I followed the instruction, and it seemed as though I did it right. We reinstalled it, and started the truck up, and it ran! It ran for about 15-20 seconds, then gas started spewing from the two stacks on the top! We shut down the engine. Every time we tried to start again, it wouldn't. We took the top off the bowl and adjusted the float, but it didn't help. Still no start, and the gas would start spewing from the stacks.
The only idea I have is that maybe the fuel pump is pushing too hard. What would make that happen?
Or perhaps a low manifold pressure not operating the power valve?
Any ideas?
Any ideas?
Yep. I made sure the carb cleaner would spray through each little port or jet. The crud that was in the fuel lines and gas tank gave us hell. We drained the tank twice. I filled the bowl on the carb with fresh gas one of the times we tried to start it. It didn't help, same result, no start, gas out of the stacks.
It's not actually coming from the air horn, it's coming out of the two vent stacks in front of the horn, over the bowl. We haven't moved the distributor, and we have double checked the plug wires. I think it's either the fuel pump pushing too hard, or the needle on the float not properly seating (though it looked fine during my visual inspection). Keep the ideas coming though. Thanks!
Well I got the gas to stop coming out the stacks, the float wasn't right. We're still having issues, so I'm going to call a friend to come check it out. I'll repost when we figure it out.
The carb does still appear to be flooding the engine. I suspect low manifold pressure not operating the power valve. Is that a likely cause?
If its flooding at idle, you need to adjust the two idle air/fuel mixture screws. If it is a holley, tighten them up and back em out 1 1/2 turns. Tune it from there.
It's a motorcraft 2150. I suspect some overlooked issue for low manifold pressure. My brother's truck has been nothing but trouble since he bought it. Not a lot of money to fix it, but loads of time and annoying problems. We do currently have the mixture screws set at 1 1/2 turns. We're going to try some stuff tomorrow.
His '84 sat for about 6 years, and now everything that could go wrong did. My '74 sat for 6 years, and before I removed the gas tank (for resto purposes), it fired every time you turn the key.
