302/5.0 HO starter. - Ford Truck Enthusiasts Forums
302/5.0 HO starter.
Old 05-27-2009, 03:05 PM
savage066 savage066 is offline
savage066 is starting off with a positive reputation.
302/5.0 HO starter.
I swapped a 5.0 HO into my F-150 and used the old 302 bellhousing, and the starter won't engage the smaller diameter flywheel. Will this be solved by using a mustang starter, or do I need to use the mustang's bellhousing?
Old 05-27-2009, 03:32 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
What was the old engine/tranny combo including the engine year, and what is it now?
Old 05-27-2009, 06:55 PM
Had a '75 302 with a 3.03 manual (you know, the toploader 3-speed). I'm using the same tranny with an '87 5.0 HO out of a Mustang GT. The only issue is that the Mustang was automatic, so I ordered the flywheel for a standard GT, which is a half-inch smaller in diameter. Maybe an inch, I forget. The starter for the F-150 wouldn't engage the flywheel, so unless I just have a bad starter...
Old 05-27-2009, 08:03 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
i think you need a starter for an 87 F150 running a manual tranny.
Old 05-27-2009, 11:34 PM
Isn't the F-150 flywheel from '87 going to be the same as the '75? I think the Mustang GT just uses a different size flywheel than the trucks.
Old 05-28-2009, 12:24 AM
Conanski's Avatar
A mustang uses a T5 so I think you got the wrong flywheel. If you still have the flywheel from the old motor count the teeth, I'm guessing it's a 164 tooth and it'll have a 28oz balance weight so you can't use it on the new motor, it needs a 50oz flywheel.
Old 05-28-2009, 08:19 AM
I have a 50 ounce flywheel, so that's ok. Are you saying the mounting point for the starter is different on a T-5?
Old 05-28-2009, 08:23 AM
I figured the T-5 housing still has to bolt up to the same block that my old bell housing does, and the starter goes in the same place...
Old 05-28-2009, 08:45 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
E4DZ11002A .. Starter (Motorcraft SA734A)
Fits: 1984/89 All Passenger Cars with 302/351W A/T or M/T.
Fits: 1985/89 F150/350/Bronco 300/302/351W A/T only.
E4TZ11002A .. Starter (Motorcraft SA738A)
Fits: 1985/89 F150/350/Bronco 300/302/351W M/T only.
Old 05-28-2009, 01:01 PM
Conanski's Avatar
Quote:
Yes the belhousing bolt pattern is the same, but there are 2 different size flywheels available for the Windsor family of motors and the starter is offset a little differently for each one. Somebody posted a pic of the 2 different seperator plates available for these motors one time but I can't find it. Here's a pic of a universal plate from summit that accomodates the two starter locations...
Old 05-29-2009, 02:25 PM
so you will need a flywheel for an 87 5.0 out of a truck. then you can use the starter from your 75
Will a 5.0 Mustang pressure plate bolt to an older 302 flywheel? jade79 Clutch, Transmission, Differential, Axle & Transfer Case 0 07-26-2016 09:49 PM
302 to 302 HO swap muddyford911 1987 - 1996 F150 & Larger F-Series Trucks 17 05-29-2009 01:39 AM
302 HO - Mustang Engines E30tdf Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 13 07-09-2007 02:49 AM
Mustang fuel injection on truck original67 Fuel Injection, Carburetion & Fuel System 4 02-12-2004 10:34 PM
302 h.o. ? valve clearance mohomustard Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 09-03-2003 12:02 AM
Tags
1990, 302, 50, bell, block, e4dz11002a, f150, ford, ho, housing, motor, mustang, possitive, starter, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
