Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
View Poll Results: Which engine for a good light weight street car.
289 2 6.45%
302/5,0 14 45.16%
351w 9 29.03%
390 3 9.68%
460 3 9.68%
Voters: 31. You may not vote on this poll
  #1 (permalink)
Old 05-27-2009, 12:03 AM
Tifford Tifford is offline
Tifford is starting off with a positive reputation.
Which engine would you choose for a 2,000 lb play car?
You will drive this car on the street. You want some performmance, both in the acceleration department and in the handling department.
Vote now.
  #2 (permalink)
Old 05-27-2009, 12:37 PM
Conanski's Avatar
Conanski Conanski is online now
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
Some of the Cobra replica cars are built around the mustang 5.0HO and many of it's other powertrain and chassis parts.. and for good reason, it delivers outstanding power to weight ratio in stock form, and radical performance when stroked and/or supercharged.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, 1.6 RR, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, and now power steering!!
  #3 (permalink)
Old 05-28-2009, 12:33 AM
Conanski........You know a lot about Ford products. If I may hijack my own thread, Where did you come across all the information that you know?
  #4 (permalink)
Old 05-31-2009, 02:14 AM
dadstan76 dadstan76 is offline
dadstan76 is starting off with a positive reputation.
Sounds like you are building a Monster Miata I'd choose the 302
__________________
If it ain't red, leave it in the shed
  #5 (permalink)
Old 05-31-2009, 09:55 AM
Conanski's Avatar
1990 Ford F-150
Quote:
It's taken 40+ laps around the sun, lots of reading, and lots more wrenching, and I'm still learning.
__________________
Paul O
  #6 (permalink)
Old 06-05-2009, 01:02 AM
410 410 is offline
410 is starting off with a positive reputation.
id say 5.0 but voted 351w im crazy and would want the extra power u get with the bigger motor the other engines would be counterproductive with the added weight
__________________
Hammer 93 F150 302
  #7 (permalink)
Old 06-07-2009, 07:19 PM
fordeverpower's Avatar
fordeverpower fordeverpower is offline
fordeverpower is starting off with a positive reputation.
a 351 cleveland would be my choice.
__________________
Matt
78 F100 390 2wd c6
79 F150 351m 4x4 c6
79 f150 390 rip
Avatar is Barry Rabotnick's emc motor!
  #8 (permalink)
Old 06-08-2009, 11:20 AM
4wheeling79's Avatar
4wheeling79 4wheeling79 is offline
4wheeling79 is starting off with a positive reputation.
late model 5 liter block. it is light wieght in comparrison to the others, the aftermarket has it covered from every angle. I would stroke it out to 347 add a good set of heads and big fat roller cam and let it eat. I have one in a 86 stang making 640hp and 680tq to the tires very fun to drive. The possibilities are endless but thats my vote
__________________
1996 F-250 XLT 460 Super Cab 4x4 4 inch lift 33x12.5 Tarra Grappler's on Pacer alloy's. Rebuilt motor, comp cam, ported heads and intake, hedman headers, wide band AFR, mass air and anderson PMS
1986 stang 351W, TFW heads, big roller cam, TKO 600 tranny + 7 yrs of my life and every pay check.
  #9 (permalink)
Old 06-08-2009, 12:55 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
Call me silly, but I'd keep it small and simple and go with a 289. I've seen what one well-built 289 can do in a '67 2+2 hardtop Mustang, and it even blew doors off several 5.0 GTs and IROCs back in the day.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #10 (permalink)
Old 06-08-2009, 03:03 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
The 289/302 is the best choice IMHO for both power & handling- the lightest engine & you can produce hp to match almost any big block.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #11 (permalink)
Old 06-08-2009, 03:16 PM
lew52's Avatar
lew52 lew52 is online now
lew52 is gaining momentum as a positive member of FTE.
Keep it light, hp to weight ratio..302 HO or if you want something crazzy fast 347 stroker...Lew
  #12 (permalink)
Old 06-10-2009, 07:20 PM
Terpfords's Avatar
Terpfords Terpfords is offline
1985 Ford F-150
My Garage
Terpfords is starting off with a positive reputation.
small block
there's nothing you can't do with a small block nowadays. 289/302's will give you plenty of clearence and as stated earlier they can be stoked out to 360 and nowbody knows.
  #13 (permalink)
Old 06-10-2009, 07:55 PM
conger's Avatar
conger conger is offline
conger is gaining momentum as a positive member of FTE.
A while ago I saw a U-tube video with a Jeep CJ jumping dunes with a 6.0 under the hood. Maybe I'm a bit biased , but I thought that was pretty cool.
__________________
04 F250 S/C 4x4 6.0psd, Viper security, Procomp ES9000s, Prodigy, Fumoto valve, Dieselsite coolant bypass filter, steel braided esof lines, Cat delete, Procomp 2 1/2" level lift & rear add-a-leaf, Autometer pillar gauges, DC1 rims on MT rubber.
  #14 (permalink)
Old 06-17-2009, 05:04 AM
doug1222556's Avatar
doug1222556 doug1222556 is offline
doug1222556 is gaining momentum as a positive member of FTE.
I'd give the 5.0 the nod.
  #15 (permalink)
Old 06-22-2009, 08:25 PM
gearhed1971's Avatar
gearhed1971 gearhed1971 is offline
1973 Ford F-100
gearhed1971 is starting off with a positive reputation.
289,baby.Rev it to the moon!!!!!
__________________
gearhed1971
1973 f100-390 4wd
1963 falcon-under construction
1951chebby special deluxe(for sale)-SOLD!!!
daily beater poontang sunfire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
