Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-25-2009, 03:52 PM
muscletruck's Avatar
muscletruck muscletruck is offline
muscletruck is starting off with a positive reputation.
budget lift kit
any ideas for budget ways to lift an early bronco?
  #2 (permalink)
Old 05-25-2009, 06:45 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
What are you planning on doing with it?
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #3 (permalink)
Old 05-26-2009, 08:15 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
gfw1985 is starting off with a positive reputation.
People have come up with a lot of diff ways to do this, not all safe, but your best bet is a complete lift kit. Duff's sells a 3.5" suspension lift package for $460. Most of the vendors sell similar systems. If you only want a little extra clearance, body lifts can be had for $150 or less. Your life depends on your suspension, not a place to be too cheap.
  #4 (permalink)
Old 05-30-2009, 12:18 PM
just offroad. 73-79 f150 lift coils work for about 7" of lift but i think they are going to be way to stiff
  #5 (permalink)
Old 05-31-2009, 10:36 PM
RCrawler's Avatar
You're not going to get 7" of lift from an F150 coil, only about 2" at the most.
What kind of off roading do you do with it? Mud, rocks, sand, combination? How much lift do you want from it? What size tire do you plan to run? How are your fabricating skills?
Jason
__________________
  #6 (permalink)
Old 05-31-2009, 11:56 PM
theyre 4" f150 lift coils. sorry i wasnt as specfic i should have been
  #7 (permalink)
Old 06-01-2009, 10:57 PM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
That coil swap isn't going to work unless you have in your build a high pinion rear-end install.... plus you are going to need longer raduis arms for the front....
I agree with gfw.... best low budget option is a bodly lift for two reasons... despite the fact that body lifts are considered ghetto these days because suspensions lift companies dominate the market due to Jeepers the 2" body lift is hands down one of the best first building blocks you can do with an EB... the reason is that after that is complete and you will have about 400 in parts with brake lines, extended clutch rod etc... you can run 33" tires...
then you can complete the next best swap to an EB which is the 351W swap because now you have the much needed two extra inches under you hood, which you will need if you swap in a 351W because a hood scoop is needed on the 302 if you run normal aluminium intake with a 4bbl and you dont want to use the expensive K&N pancake with a filter top.... IF you are talking strokers.... Why build a 347 when you can build a 408?
Then when you want to add some suspension lift you will only need the 3.5" lift to run 35s
Then when you get tired of running around with three speed and want to to the NV3550 swap you can without adding a high pinion rear... which for the 9 inch is a two thousand dollar centersection......
Body lifts migbt be out of vogue... but on a EB they are the way to start a build IMHO
  #8 (permalink)
Old 06-02-2009, 01:05 AM
RCrawler's Avatar
Body lifts are just fine, except for all of the unforseen mods needed to finish the job right. Such as radiator hoses, shroud, fuel fill hoses, steering shaft. Not to mention the body gaps and the cow catcher bumper look. Body lifts are fine, IMO, if you're just after a look. But they will do nothing for suspension performance and travel.
Spend your money on a good set of front coils 3.5-5.5", depending on your tire size and a set of F250 shock mounts for the front. If you have the capabilities, a shackle hanger flip will net you about 4" of lift and take advantage of the soft, good traveling stock springs. Match it up with the inboard shock mount kit. This will give you some very decent travel for a minimal investment. Of course, you will need some steering and alignment correction. And with the extra travel, you will need longer drivelines and brake lines.
Jason
Unless you're specifically talking about stroker Windsors, they aren't that big of a deal, BFett. EFI was the best bang for the buck performance mod I've ever done to an early Bronco. With impressive power and throttle response, there aren't too many stock stroke Windsors that will outpull me. If I ever do build a new engine for mine though, it will be a big cube Windsor with injection.
__________________
  #9 (permalink)
Old 07-01-2009, 11:52 AM
i think im going to do the same as my brother did on his eb. 1/2 ton chevy lift leafs at all4 corners
  #10 (permalink)
Old 07-05-2009, 04:32 AM
mauicruza mauicruza is offline
mauicruza is starting off with a positive reputation.
So you're looking to fab all the brackets to run chevy leafs onto your stock eb axles or are you going all-chevy? It's going to be some work but I quess in can be done. If you're getting most of your parts for little or no cost then I doubt it'll be a "budget lift". You may be better off pricing a complete EB lift kit. Less headaches IMO.
Tags
eb , kit , lift
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
