Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-25-2009, 04:34 AM
puppyduks puppyduks is offline
puppyduks is starting off with a positive reputation.
Lifter adjustment?
Can the lifters be successfully adjusted on the 4.0l OHV engine? My truck is a 2000 but had a rebuilt engine put in in 2005. The lifters are starting to tap at 87,000 miles.
  #2 (permalink)
Old 05-25-2009, 02:12 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
The 4.0 OHV engines had non-adjustable lifters. The tapping is from wear on the pushrods / rocker arms. You can buy the replacement sockets for the rocker arms and new pushrods and install them.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #3 (permalink)
Old 06-02-2009, 11:18 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
They are hydraulic lifters, and self adjust, but it is fairly common for 2.9/4.0 OHV engines to have premature lifter failure. If its a knock or a rapping then its the lifters collapsing, but if its "clicking/light tapping" like noise, then its probably valve train wear like it was said.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
Tags
29 , 29l , 40 , 40l , adjusment , adjustable , adjustment , ford , lifter , lifters , ranger , sohc , tap , v6 , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
