wiper issues
on
My 1997 F250 does this as well. I have determined that the turn signal / wiper switch on the steering column is the source of the problem. Sometimes the switch doesn't make contact and the wipers simply stop working. When this occurs, I can simply tap the switch and it will make the connection and the wipers will work again. It never does this in the non-intermittent wiper options. I believe that a new turn signal / wiper switch is around $90.00.
The next time yours acts up, try lightly tapping the turn signal / wiper switch on the steering column.
on
tried that to no avail. They came on today when i adjusted the dash lights, but who knows, about that.
My windshield has been replaced, and my truck comes from az and is mostly garaged here in ky, but i will take a look.
Sometimes they will stop mid stroke other not start at all. in any position.
on
just for more confusion (seriously, something to check) on my F150 years ago, I was having problems with the intermittant delay, turned out to be the motor, even though there is an intermittant governor on my F150, it is behind the glove box. it was not the trouble, but something like that could be going bad in yours.
hope the idea's help you!
Corpsman24
09-12-2012 03:53 PM
fordsgofaster
12-25-2010 07:26 PM
