Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-24-2009, 05:05 PM
Adventure Adventure is offline
Adventure is starting off with a positive reputation.
DTC Codes C1155, P1408, P1703
So, the ABS light has been one for a few months now. I bought a OBDII/ABS scanner and C1155 is the reported problem, left front wheel sensor circuit failure. I figure that means it's the speed sensor on the front left side tire. Not a huge problem in replacing it, just really didn't want to take the hub apart but it sames necessary to access sensor bolts which are covered by the rotor.
While playing around with the scanner, I ran the KOER test and got errors P1408 EGR Out of Self Test Range and P1703, Brake On/Off Out Of Range. Those two items I don't have a clue on where to start. Can any of you provide a starting point for resolving them?
  #2 (permalink)
Old 05-24-2009, 05:17 PM
Just find out the P1703 is because you need to press the brake pedal once during the test.
I was also getting a P1780, for that one you need to turn the overdrive on / off once during the test.
Still getting the P1408 EGR one however.
  #3 (permalink)
Old 05-25-2009, 08:26 PM
Fordcr Fordcr is offline
Fordcr is starting off with a positive reputation.
My 2004 E350 just popped the ABS light. Would you mind telling us what reader you bought?
  #4 (permalink)
Old 11-06-2009, 09:24 AM
It's an innova 3150.
Replaced the front left wheel sensor and that problem (ABS light) was corrected.
Tags
0405 , 05 , abs , c1155 , code , codes , diagnostic , dtc , f150 , ford , list , p1408 , p1703 , p1780 , trouble , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
