Auxiliary Switches - Ford Truck Enthusiasts Forums
Auxiliary Switches
Old 05-24-2009, 01:27 AM
kankles747 kankles747 is offline
kankles747 is starting off with a positive reputation.
Question Auxiliary Switches
i have a custom mount that has 4 switches on them but am indecisive on what i want to use them for can anyone help and put there 2 cents in. thanks
Old 05-24-2009, 02:02 AM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Has (all 4) it been mounted in the truck already?
Old 05-24-2009, 02:38 AM
yeah they have...2 are taken by offroad lights and radar detector but got two empty ones
Old 05-24-2009, 03:01 AM
Tylus's Avatar
Tylus Tylus is offline
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
can we get pics of your current setup?
most guys mount 4 switches on the oval piece below the radio that has the cigarette lighter
1. 6" offroad lights behind your grill
looks awesome especially if you have the Honeycomb or the Roush grille
2. backup lights on the bumper
light up the area behind you when backing up
3. ???
4. ???
Old 05-24-2009, 03:43 AM
yeah il try to get pics up tomorrow and yeah i have the lights behind my honeycomb grille and i just hardwired my radar detector to a switch so the cold cord isnt hanging everwhere
Old 05-24-2009, 03:45 AM
and since i have a bench front seat on the dash below the change holder/ashtray theres like a cubby hole i made a panel for that and stuck the switches there
Old 05-24-2009, 08:44 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
You can use one of the switches to control a cutout relay for a set of air horns.
[IMG][/IMG]
Old 05-24-2009, 12:41 PM
how much for a set of air horns
Old 05-24-2009, 01:06 PM
shorebird's Avatar
I purchased mine from Siege Engineering's E-bay store for $185. They are not showing any product on E-bay or their website. There are many other systems on E-bay at; air horn, eBay Motors, Electronics items on eBay.com. One thing is the system using a storage tank allows you to be able to air up tires. My gallery at; 2001 Ford Econoline 4x2 - Tech Photos has pics of the system installed on my tow truck. Sets run from @$200 ↑. I recommend a system that has the tank and compressor as separate components. I wired mine so that a relay is open if the switch is in the off position. The relay closes when the stitch is on. This allows power to pass to the air horn valve solenoid when the regular horn receives power from the horn button. Aux switch off = regular horn only. Switch on = regular horn + air horn.
Old 05-24-2009, 02:23 PM
oh ok gotcha well thats pretty awesome that it lets you air up your tires...thats a plus
Old 05-25-2009, 11:54 AM
shorebird's Avatar
I added a quick coupler to my system along with a 50' air hose.
Old 05-25-2009, 06:18 PM
thats a really smart idea...good looking out...but at the same time a costly accessory but im sure its gotten its use
Overdrive switch blowing PCM fuses - help Dirtfarmer69 1999 to 2016 Super Duty 13 11-05-2014 06:34 AM
headlight switch capelo 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 06-24-2013 04:27 PM
map light fix, over head console lights rockcrawler_101 Excursion - King of SUVs 10 05-02-2013 09:33 AM
Headlight Switch Connector Replacement, '92-on asavage Aerostar 4 05-07-2012 03:27 PM
question on wiring for Carling switches tjc transport Electrical Systems/Wiring 4 05-22-2009 06:54 PM
Tags
aux, auxiliary, f150, f250, ford, set, switch, switches, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
