Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 05-23-2009, 04:02 PM
mickey6566 mickey6566 is offline
Garage is empty, add now
mickey6566 is starting off with a positive reputation.
96 f-150 throttle body
Any suggestion will be appreciated.I have a 96 f-150 5.0,went to change the coolant and found a small hole in the bottom coolant elbow attachted to the throttle body.Went to investigate the hole and the peice came off in my hand.Guess I was lucky to be home.Does anyone know any fixes or am I bound to buy the complete throttle body assembly?Thanks
  #2 (permalink)
Old 05-24-2009, 12:04 AM
Blurry94's Avatar
Blurry94 Blurry94 is online now
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Can you post a pic?
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #3 (permalink)
Old 05-24-2009, 03:03 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
MAF or SD truck?
and got a pic?
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #4 (permalink)
Old 05-24-2009, 05:54 AM
lew52's Avatar
lew52 lew52 is online now
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Its the coolant line that keeps the TB warm in the winter time . If you live in a warm climate you can just bypass it ?? . If not ?? I think the fitting is pressed in , dont know if they sell them . You may need another TB . Lew
  #5 (permalink)
Old 05-24-2009, 08:34 PM
Blurry94's Avatar
1994 Ford Lightning
If the exhaust gases recirculate from the heads through the intakes, to the throttle body, you'll need to plug the exhaust gas port at the lower intake to keep the throttle body from getting too hot.
  #6 (permalink)
Old 05-26-2009, 10:50 AM
Beechkid Beechkid is offline
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
If you have or can fab up the pieces, i bet JB Weld would work well.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #7 (permalink)
Old 05-27-2009, 01:04 AM
my94lightning my94lightning is offline
my94lightning is starting off with a positive reputation.
I believe that the 5.0 and "standard" 5.8 truck have dual bore TB's. the coolant line is there to "cool" the throttle body, the egr valve (very hot) heats up the TB and the coolant is there to keep it from over heating the TB.
if you have deleted or deactivated the EGR, than you can either bypass the lines togetter or cap them off.
If the EGR is still active then maybe you can drill and tapp new hose fittings to the TB, dunno, but I would try that before buying another one.
good luck.
Tags
150, 1994, 58, 96, assembly, body, coolant, expedition, f150, fitting, ford, line, tee, throttle, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
