Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > Flathead V8 and Flathead 6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-23-2009, 06:48 AM
HOILERAUTO's Avatar
HOILERAUTO HOILERAUTO is offline
1969 Chevrolet Camaro
My Garage
HOILERAUTO is starting off with a positive reputation.
hard starting flat head
have a 53 239 cui ,new carb, fuel pump and fuel filter when it sits for a few hours or over night,cranks for a long time before it will fire off ,seems to start ok when engie is hot, shut off & restarted in a short periord of time..any ideas??? fuel pumps is a brand new napa
  #2 (permalink)
Old 05-25-2009, 08:39 AM
kotzy kotzy is offline
kotzy is starting off with a positive reputation.
Sounds like the carb is drying up and it takes the pump a long tome to refill it. The pump is new did you replace the pushrod? At least I think the late flat head still had the pump mounted back on the center of the intake. Too short a stroke of the pump would limit the volume of fuel delivered. kotzy
  #3 (permalink)
Old 05-26-2009, 05:40 PM
Beechkid Beechkid is offline
Beechkid is gaining momentum as a positive member of FTE.
I'm thinking fuel drain back as well
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #4 (permalink)
Old 06-09-2009, 03:38 AM
55 f350's Avatar
55 f350 55 f350 is online now
1953 Ford F-100
55 f350 is starting off with a positive reputation.
the guy's are right about it draining back but i'll be dained if i can figure how with a mech. pump . maybe like suggested to short a stroke on the rod and / or maybe your rod is bent ?was gonna be a smart aleck and suggest you yell contact and spin the fan a lil' harder..... or threaten to replace it with a more modern v-8....
__________________
thats because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { dont } know especially to newcomers. were on a mission to impress you and make you beleive we are all knowing !
  #5 (permalink)
Old 06-09-2009, 02:18 PM
Back in 1953 carburators all vented externally so if the heat riser on that engine is stuck in the closed position the carb base is pretty hot. Shut off the engine and the fuel boils out thru the vent. Later carbs vented in the throat and flooded engines resulted in the same condition, these are one of the ways to drain the carb bowel. Also a high float level will result in siphoning of the fuel out of the bowel. With a needle and seat controlling the level it can't return to the tank thru the fuel pump. kotzy
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
