Clutch Slave Cylinder "Quick Disconnect" - Ford Truck Enthusiasts Forums
Old 02-14-2002, 01:35 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Old 06-13-2002, 01:35 AM
kendog kendog is offline
kendog is starting off with a positive reputation.
Post Clutch Slave Cylinder "Quick Disconnect"
Looking for assistance in disconnecting a jammed or stuck "quick disconnect" on an internal slave cylinder on a 1990, 4.9L, 5 spd. Any suggestions would be appreciated!
Old 06-17-2002, 09:09 PM
rdhensley rdhensley is offline
rdhensley is starting off with a positive reputation.
Just struggled through this myself this last Friday.
I ended up using a couple of very small screwdrivers to push the white teflon ring down below the level of the metal before the "quick" disconnect - disconnected.
While pushing the ring down, I rotated the two collars and it finally came apart.
Hope this helps.
RD
Old 06-18-2002, 09:10 PM
4x4x4x4 4x4x4x4 is offline
4x4x4x4 is starting off with a positive reputation.
I made one a couple of years ago out of a fairly thick piece of sheetmetal.I cut out a u shaped section at the end just large enough to fit over the line and it worked decent.I'm sure a good parts store sells a special tool if needed.
wheels 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-13-2004 01:08 AM
is this common 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2002 02:38 AM
Wheelbase 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 01-14-2002 10:06 AM
Overheating 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-11-2001 11:13 PM
Tags
1994, 97, clutch, cylender, cylinder, disconnect, disconnecting, ford, hose, internal, line, quick, ranger, slave, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
