2008 Nav. Brake Bleeding advice, Please... - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 05-23-2009, 03:18 AM
00 Nav 00 Nav is offline
00 Nav is starting off with a positive reputation.
2000 Nav. Brake Bleeding advice, Please...
Hi there, i was wondering if you guys can give me some pointers on how to properly bleed the brakes after changing out some brake pads. I know the order is RH rear, LH rear, RH Front and last is LH front. Longest to shortest routes get bled first....
I have a few questions...
1.Does the veichle have to be on or off when doing this...?
2. Can someone give me their way of doing this with my son at the brake pedal pumping and holding...? How many times to pump before holding with steady pressure?
3. Approx. how much brake fluid should i buy to change it out during the bleeding process....? I don't think it's been done ever, fluid looks like coke, really dark brown.
I tried this evening, but still had that mushy feeling....I had my boy pump 3 times, hold on the fourth pump, i would then open the bleeder screw until no fluid came out, then tighten....
Please, someone shed some light.....? Thanks
***** I just edited the tittle i meant 2000 and not a 2008. *******
Old 05-23-2009, 03:46 AM
Tylus's Avatar
Tylus Tylus is offline
Nuclear Machinist Mate
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
OFF is fine
10 pumps
see my personal method below
get at least 1 qt of the stuff. the biggest quantity is the reservoir itself...but you've got probably 30-40 ft worth of brake line to flush out.
you just put air back into the system
after your boy pumps up the brakes, have him hold the pedal with pressure.
then you crack that bleeder valve slightly. be ready to shut it immediately
warn your boy to tell you prior to the brake pedal hitting the floor so you can shut the bleeder.
DO NOT ALLOW THE BLEEDER TO BE OPEN WITHOUT FLUID FLOWING OUT...this means the fluid isn't displacing air...so air is going back inside the line
basically, the process will be like this:
1. Empty Reservoir, clean out, and refill with new fresh brake fluid.
Make sure to use a brand new bottle.
Brake fluid absorbs water from the air...so if it has been opened, it is basically no good unless you opened it just a very short time ago
also, be sure to get that Reservoir Cap back on good...it makes quite a mess if you don't
2. pump 10 times (if possible)
3. keep constant pressure on brake pedal
4. at wheel, crack bleeder valve
5. shut bleeder valve when the following occur:
5a. Clean Fluid arrives
5b. Brake pedal approaches floor
5c. You feel you've done enough venting
Whatever you do, keep that valve shut unless fluid is flowing out...otherwise air gets in
6. Check and refill your reservoir (ensure the cap is on tight afterwards)
7. Repeat as necessary for each wheel...and until you get fresh new fluid at each wheel
hope I am able to help you some
several issues here...my stuff in bold mixed in with yours
DO NOT DRIVE YOUR VEHICLE UNTIL YOU HAVE PROPERLY BLED THE BRAKES. YOU CURRENTLY HAVE AIR IN THE LINES.
The sponginess is the air getting compressed with each brake useage. It's not safe to be driving until bled
Hopefully the air stayed at each wheel, and hasn't migrated to your ABS proportioning block. If the air makes it to your ABS block, you'll have to visit a Dealership. There is no DIY way to bleed that F'ing block that I know off....so lets just hope nothing moved around.
Old 05-23-2009, 04:08 AM
Is this the same for a 2000 model, i accidently put 2008, i have a 00 model...? I will buy some dot 3 tomorrow and retry this using this method if infact is the same for a 2000 Nav. model. Any more advice or suggestions, im all ears and thanks!
Old 05-23-2009, 04:17 AM
Tylus's Avatar
yeah man, this should be pretty much what you'll do for any car on the road.
I found out about that damn proportioning block on my 1993 Bronco that had 4 wheel ABS...nightmare. caught on fire, ran me about $200 for repairs
But the basics of every single brake system are the same.
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
When you go buy the fluid do yourself a favor and grab a one-man brake bleeder. It makes the job MUCH easier and takes the guess work out of it.
Here's another option for future reference. Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
Old 05-23-2009, 05:47 AM
Tylus's Avatar
well hell
completely forgot about those things
good suggestion Monsta
Brake Bleeding Procedure Stewart_H Excursion - King of SUVs 35 06-26-2014 05:58 PM
'86 Brake bleeding questions mozzles Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 23 09-28-2012 11:44 PM
Back brakes Won't Bleed TNLuke 1973 - 1979 F-100 & Larger F-Series Trucks 2 09-12-2011 11:23 AM
I Completely Give Up on This Barke Issue. Know one Know the Answer. NC2X4 1973 - 1979 F-100 & Larger F-Series Trucks 27 09-15-2010 11:54 PM
Brakes = No Brakes XzXPatrickXzX 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-30-2009 09:35 PM
Tags
2008, 4x4, bleed, bleeding, brake, brakes, excursion, expedition, f150, ford, limited, lincoln, navigator, order, process
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
