What PN gas lift gate struts?
Ref. 70s Ford cap with original sliding lift gate struts: I am replacing my
fiberglass lift gate that is broke in 3 places with a identical lift gate.
I intend on replacing the sliding struts with gas struts. Length: Max 14", Min 7.5". The total weight is 40 lb.
What brand, part number and store/web sight is suggested?
Since writing this request, 29 Ford truck owners have read it and no one has done the research.
I emailed a manufacture the same question. No reply either.
I would take one of the sliding liftgate props with you to a "good" auto parts store. They can measure the length of extension and retraction and suggest what would work best. I am staying all original with my canopy/camper. Jeffs bronco graveyard sells the sliding liftgate prop in their bronco section. 77 and earlier Bronco and canopy props are the same.
There's a reason for the swap to the gas cylinders (struts). I left my lift gate open as I often did
with my 59 Ford wagon. Crossing railroad tracks, the lift gate jumped and came down
on one side. The fiberglass frame broke in 3 places. I bought a complete Ford cap that
sat in the grass for years. The lock and latches were rusted solid. The screws had to be
drilled out. Gas struts of the proper strength should keep it open and not mess up when
I want to close it. (locked up on one side then the other etc)
I have emailed STRONG ARM GAS LIFT SUPPORT twice with the info for a quote. ( total wt. 40lb. Max 14" Min 7") No reply yet.
Ryan50hrl
04-08-2002 11:31 PM
