Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-23-2009, 12:06 AM
jordandice jordandice is offline
jordandice is starting off with a positive reputation.
Question Why did my tranny casing break?
Truck- 1999 f250 v10 5 speed 4x4
What happened - Was driving back home from colorado (1000+miles) got some bad vibrations around 70mph. checked driveline,ujoints... everything was tight.(replaced all ujoints and had driveline rebalanced 5000 miles ago.) drove around 60 the rest of the way and vibration was much less but still a little noticeable. 10 miles from home started to accelerate at a light and the truck went bang, (metal braking) and I lost power to the wheels. towed it home.
Aftermath- The casing broke all the way around where the transmission mounts up to the transfer case, right where transmission shaft goes into transfer. Took tranfer case out and it seems fine, spins freely, no scary noises. Nothing seems wrong with the tranny either. Since the transfer is out I can put it in any gear while running and the shaft spins fine, has no marks or dings and again no scary noises.
What could've caused it to break?
Should I just replace the casing and make sure everything is put together correctly or should I take it to a tranny shop for further investigation?
What would be the best way to find that casing?
Let me know if any more info would be helpful.
Thanks for any info
  #2 (permalink)
Old 05-23-2009, 12:56 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
I'd ask your Ford dealer when you order your new one, maby they have seen this before. Were the bolts good and tight ?
__________________
'79 F250 13" lift 42" Super Swampers
  #3 (permalink)
Old 05-23-2009, 02:04 AM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
i've seen it happen a couple of times before in my dealer years, it occurs when the t-case bolts start to work loose form the tranny adapter.
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #4 (permalink)
Old 05-23-2009, 02:42 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
What transmission is that? (ZF5??)
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #5 (permalink)
Old 05-23-2009, 06:06 AM
Lazy K Lazy K is offline
Lazy K is gaining momentum as a positive member of FTE. Lazy K is gaining momentum as a positive member of FTE.
For exploded diagrams and for parts motivegear.com is good.
  #6 (permalink)
Old 07-01-2009, 12:45 AM
madrockwyo's Avatar
madrockwyo madrockwyo is offline
madrockwyo is starting off with a positive reputation.
check for a loose/broken motor/trans/tcase mount
__________________
Scott
1979, F250 4x4 400/C6 reg cab XLT Ranger Chrome Yellow/ White
2000 Extended cab Ranger 4x4 V8/auto
1979 F150 4x4 351m/manual parts truck; 1963 Ranchero rolling chassis
1967 Bronco wagon 4x4 289/3 on tree
1961 and 1963 Ford Falcon Rancheros 170/3 on tree
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
