SoCal Pickups Inc
SoCal Pickups Inc
I know that they closed down six or seven years ago, but any of you use one of their harnesses? I have one that was made in 1989, but sadly the instructions were thrown out. Ya, it's been in a bag for twenty years, but it looks so pretty. There is only about forty wires in the whole thing. I plan to use it, but get freaked out when I have a pile of wires in my lap. Anyway...
If the fuses are labeled use a ohm meter, pull one fuse at a time. Put a ohm meter lead on one end of the fuse mount.Touch the other lead to each wire until you have a meter reading and label the wire. Repeat until all wires are accounted for and labeled. List all components that require a electrical circuit. Draw up a diagram and follow each circuit installation until all are completed. Continue asking questions as they come along until finished. Several members can provide sample diagrams if you describe you plans/components. chuck
I am currently doing: Having laid it out on the ground have a general idea of what/where. The truck is a '53 F100. The motor is a carburated 1980 302. What I dont need: horns, flashers, radio, heater, wipers, spotlight. I laid it in the truck and everything looks close. I plan on getting a 56 headlamp switch from Sacramento Vintage tomorrow. So... after looking at many diagrams on FTE and pacing the garage I plan to install it. Do i want to shoot power off the alternator up to the headlight switch or down to the starter? Do I draw ignition power from the headlight switch to the ignition?I would like the lights to work all the time. I know this is doable without a specific instruction sheet, just don't really wantto cut into the harness. Ramble...
You need to run your alternator power up to your power distribution point then through your ammeter ending up at the battery post of the starter solenoid. So if you are installing fuse blocks, and you should, then run alternator power down to the fuse block supplying unswitched power then through the induction loop on the back of the ammeter, and out to the starter solenoid battery terminal. Distribute power to each item out of the fuse block.
The ignition switch is powered by an un fused wire running up from the Hot items fuse block up to the Battery Post of the ignition switch.
Set up a second fuse block to handle "switched" items and power that fuse block off the "ACC" terminal of the ignition switch. Again, distribute power to each switched item off the fuse block. Check out my #4 gallery for wiring diagrams.
This morning I wired a little bit up. I ran a wire off the BAT on the alternator back up to the '56 headlight switch. Is it ok to back feed power through the system to charge it? Also ran a wire off the A (on the external regulator) to the ACC on my ignition. That means it will boot up when it is running ya? Not using the I (on the Reg). Ran a wire from F on alt to the F on reg. grounded both the alt and reg to body. Then I ran a wire from the S on the reg down to the always hot side of my starter. I saw a bunch of diagrams on here and that seemed the most basic, which will suit my needs. Does all or any of this sound right?
Let’s complicate things.
IMHO you might want to rethink the ammeter (if that’s what you are using) as all the current (except the starter) is going through it (in series) behind the dash, and can make for nice smoky hot things, a voltmeter which still gives you battery/charging condition is safer as it is wired in parallel with minimal current.
TheCoach
01-11-2015 12:31 PM
jtharvey
19
07-25-2012 11:28 AM
