E4OD Problem :( - Ford Truck Enthusiasts Forums
West Virginia Chapter Join Chapter, Leader: Archion
E4OD Problem :(
Old 05-22-2009, 07:29 PM
67 White Lightning's Avatar
67 White Lightning 67 White Lightning is offline
67 White Lightning is starting off with a positive reputation.
E4OD Problem :(
I am having a problem with my transmission not wanting to go into gear anymore.
I pulled the engine and trans out, replaced the front pump seal on the trans, got rid of the smog pump and egr on the engine, along with plugging all the vaccum lines leading from the egr/smog pump.
I reinstalled the engine and trans, took it for a test drive around the block, the trans kept coming out of gear (low on fluid), took it to the part store to put more fluid in and as soon I turned in the store the trans stopped working at all and the truck won't move.
I thought that maybe there wasn't enough fluid in the trans, so I went and bought more to make it 16 quarts as the manual said, but nothing! I thought maybe the filter loosened intself, since I've changed the filter and fluid also. So I dropped the pan and the filter was in place. Refilled it up and still nothing.
I plz need any feedback..Thanks..
Old 05-23-2009, 03:06 PM
msgtg's Avatar
msgtg msgtg is offline
msgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to beholdmsgtg is a splendid one to behold
Bummer Dude....I'm not a tranny guy so hang tight till one of them checks in.
The other alternative is to go check in on one of the tranmissions boards here on FTE.
Joe
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
