99 F150 Blower Motor Problem - Ford Truck Enthusiasts Forums
Old 05-21-2009, 09:49 PM
dft747 dft747 is offline
dft747 is starting off with a positive reputation.
My 1999 F150 193000 miles, is in great shape and runs great. The Blower motor control switch has four positions. The fan speed only increases in the last two positions. What can I do? Change the switch, Is there a relay?
Old 05-27-2009, 07:23 PM
FTE Trigger's Avatar
FTE Trigger FTE Trigger is offline
FTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to allFTE Trigger is a name known to all
Quote:
Hi and Welcome to FTE!
...Thread Moved to the 1997 - 2003 F150 forum..
Old 05-27-2009, 07:57 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
It well could be the switch,but my first thought(old school auto electrical) is there may be a "Ballast resistor" that controls the actual motor speed. These "resistor blocks" we placed in the air ducting system for cooling purposes.The resistors Im speaking of are actually just coils of wire in varying lengths.
The switch position routed B+ voltage to specific "taps" on this block that created resistance in the circuit,controlling how much voltage was eventually applied to the blower motor.
With ALL that being said,Im not sure if this applies in this case,but its worth a shot.
Old 05-28-2009, 04:12 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
The blower motor resistor is located under the dash on the passenger side. Get down on the floor and look up. There is a four wire connector to unplug from it, then two screws to remove to get it out. Good luck!
02 F150 Blower Motor inop in panel and floor positions Matt Castelow 1997 - 2003 F150 2 12-11-2015 01:39 PM
Blower Motor brandonellisce 2009 - 2014 F150 0 06-19-2015 06:58 PM
Blower motor not working in 2009 e350 MikeBlansfield 1968-2013 Full Size Vans 7 10-16-2014 07:02 AM
98 F150 Blower Fan BIZZEEROG 1997 - 2003 F150 7 12-21-2005 03:20 PM
93 f150 heater blower problem pursable 1987 - 1996 F150 & Larger F-Series Trucks 3 02-05-2004 09:54 AM
Tags
1997, 1999, 99, ac, access, blower, control, f150, fan, ford, motor, problem, relay, resistor, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
