400 Head Gaskets Leak (New Rebuild)
I just started my 77 4x4 400 after complete overhaul and both head gaskets leak coolant (LF near intake manifold RR) there is also water in the oil.
THe heads were surfaced and block deck seems flat. I did install a used Performer 400 intake. Fel-Pro gaskets were used.
Does any one have any tricks to make these seal or insight as to why they may be leaking?
I plan on replacing them and coating gaskets with copper spray-a gasket.
Any advise would be appreciated.
did you check flatness with a straight edge and feeler gauge?
i don't see why unless you didnt torque down the bolts.
Derrick Stiriz
02-12-2017 09:25 PM
DrZoom
20
12-22-2016 09:13 AM
BigMikeUGA
07-05-2011 12:27 AM
