1985 f250 Exhaust
1985 f250 Exhaust
Anyone have any good layout plans for a dual exhaust?
i don't want the conventional dual though, I am hoping to have the exhaust exit right behind the driver and passenger door.
i'm replacing all of the exhaust pipe, minus the exhaust manifold and just wanted to know if anyone else happened to have a layout like this, or similar to this.
BTW, it's not a 4X4, and it has the 2bbl 351W
Have each side cross to the outside of the frame just behind the radius arm bushings. Then run it along the outsides of the frame to where you want it and dump it or point it out the side. You will have plenty of room for a muffler/glasspack/cats if you want any...but I dont recommend them
Hittman-Since I live in Nebraska, I don't need to pass any inspections, and I am not too concerned about the sound, i have a good enough sound system to kill off some of the interior noises.
Sycostang- I was thinking the same thing, I like the the layout of the stock passenger side, I am going to dry and make it look like that, but the driver side is going to be different, the gas tank gets in the way of where my muffler would be.
Having the exhaust pipe come under the frame shouldn't cause any clearance problems, should it? (it's either going to be a 2 1/4" or 2 1/2" pipe)
I don't want it to exit any where near the back of my truck, I would like for them to be right up behind the cab, it's more unique, that and it costs less to have them dump behind the cab rather than the wheels. Less exhaust pipe is needed
I want one pipe on each side of the cab, one from each exhaust manifold.
Gibby55
05-26-2014 11:53 AM
jayro88
10-13-2012 08:59 PM
Drevil
09-07-2006 04:39 PM
