Problems with a 98 5.4L
Old 05-20-2009, 09:41 PM
ddwood55's Avatar
ddwood55
ddwood55 is offline
This vehicle belongs to a friend of mine. IT's a 1998 E250 Ford van with 5.4L automatic. It's an old Hyster service van, he bought 5 or 6 of them various years. He brought the van over with a bad miss. Check engine light was on so I pulled codes. It was a missfire cylinder 1. So we decided to put plugs and boots on it. The plugs had never been changed the van has 220000 miles on it. I changed the plugs and boots and it doesn't run any better, the light is still on.
Here's where I need help, it now has a code P0354 Ignition Coil D Primary / Secondary Circuit Malfunction.
Can someone give me some info on what I need to do?
Thanks,
Delos
Old 05-21-2009, 07:48 AM
l-m tech's Avatar
l-m tech
l-m tech is offline
that would be a bad coil on cyl 4.when you chang a plug for a miss the coil should be changed not just the boot.
Old 05-21-2009, 11:09 AM
2000Ford2000's Avatar
2000Ford2000
2000Ford2000 is offline
However his original problem was with cylinder #1. Since you had all the COPS, boots, and plugs out, this code is likely that you didn't get the COP electrical plug on good, on the #4 cylinder. A COP failure would "usually" give you a P0304.
Check the electrical plug. If OK, swap the COP with one from another one you can get to easy, and make sure that the code shows it moved with the COP. COPs are too expensive to take a chance, IMHO. But I'd give it about a 99% chance its the plug. Don't just push it in either. Look in the plug and the COP to make sure you didn't break off or bend something on reinstall.
Old 05-21-2009, 03:09 PM
ddwood55's Avatar
ddwood55
ddwood55 is offline
Thanks!
I check out the plug connectors tonight. Yes the original misfire was on #1, however when I reinstalled the COP's I put the one from #1 over on #5 just in case it was possibly a bad COP.
I bet you are right, I didn't get it plugged in good or possibly bent the connectors.
Thanks again,
Delos
Old 05-22-2009, 02:02 PM
ddwood55's Avatar
ddwood55
ddwood55 is offline
That's what it was, not making good connection. Looks like I didn't get the plug pushed all the way on.
Now if I can just get the A/C figured out on this thing, I can get it out of my driveway.
Thanks,
Delos
Old 05-22-2009, 06:16 PM
2000Ford2000
Thanks for letting us know it worked. It's always nice to know if I was guessing right.
2001gocougs
Modular V8 (4.6L, 5.4L)
10-21-2020 09:55 AM
bataa
05-03-2015 06:14 AM
bataa
05-02-2015 03:57 AM
fttang
02-13-2014 07:32 AM
ldfry001
09-14-2013 09:51 AM
Quick Reply: Problems with a 98 5.4L
