Hi,
I have a Wheel Horse with a Kohler K301 12 hp. It seems to be one of the later ones.
When I was out mowing today, it would lose power, slow down, and backfire through the exhaust.
I changed the fuel filter, and filled the gas tank (it had some 50:1 mix from my chainsaw -- but I've done that many times) No help.
I put a scope on the points and the plug wire -- doesn't seem to be ignition. Also, the regulator seems to be trying to keep it going, but it just can't.
It happened after it warmed up a bit, and it generally will run longer at low speed. If I crank up the throttle it usually starts to fail fairly quickly.
It was doing this a couple of years ago and they did a head gasket. points, cap, fuel filter, air filter and fuel shutoff.
Was better after that, but I don't think that they ever really identified the problem.
I'm guessing that either something is making it run rich, or the the valves might be sticking -- but I'm far from an ace at this stuff.
Greatly appreciate any thoughts
__________________
ford2go (hj)
Wish I had -- F150 I6 5 speed
Have E350 RV
" backfire through the exhaust" happpens when unburnt fuel hits the hot metal inside the muffler.
The condition occurring and worsening after the tractor has run for a while fits with a faulty coil. As it heats up and expands as a result, an intermittent break inside the coil can show itself by causing erratic spark.
If possible, run it until it starts happening and put a spark tester inline with the spark plug. You should be able to discern intermittent firing.
If you don't have a spark tester, an timing light also will show an intermittent spark with the irregular flickering of the light.
This is only true if the spark is cutting out completely, not just a weakened spark. A weak spark lacks the voltage to jump the gap across a tightly compressed air and fuel mix, but might be strong enough to trip the timing light and make it flash. A bona fide spark tester with a wide air gap (about .166") will show whether or not enough voltage is present to jump the gap under compression conditions.
I don't think that it is a fuel issue.
Let us know what you find out!
__________________
97 250 PSD Ex Cab Sd 4X4 ZF5 135k
6637 in, 4" stainless ex
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
Marinco block heater tap
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
SiriusXM music & talk
Hula HP
EBPV brake
"I tried being reasonable. I didn't like it."
What color is the spark plug right after it dies. Very thick soot/wet indicates far to rich or poor ignition/spark. White ash-like deposits mean its leaning out.
A good fuel mixture will yield a fairly clean electrode with a light coating of tan-ish deposits, which is how my K301 runs.
This may sound dumb, but have you checked to make sure its not soft-seizing?
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
I will try to check the ignition again. I did wonder if it was a coil problem.
But, I did put a scope on it with a secondary ignition probe. Had the points on one channel and the spark on the other. Didn't see any evidence of misfire as it started to fail. Will look at it some more -- or maybe just try a new coil, etc.
As to Lead Head's comment -- I have a vague idea of what you mean by soft seizing, but I have NO idea of how to check for it. I'd appreciate any enlightenment.
Thanks,
__________________
ford2go (hj)
Have E350 RV
Yes, the K301 does have the automatic compression relief. I suppose its possible it could be re-engaging, but usually once its deactivated, it stays off once the engine is upto speed because of the flyweights on it.
__________________
- Ian
Doesn't seem to be ignition, and it's running way rich. Plug was sooty -- new plug started to turn black after about 10 minutes(doesn't seem to be oil).
It quits with a different coil, different plug wire and a new plug.
Planning to put in a carb kit and a float kit, but... how can I get the float seat out?
Only thing that fits is a pliers -- and they caused a little damage without breaking it loose.
Special tools ? Other tricks?
Thanks,
__________________
ford2go (hj)
Have E350 RV
__________________
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
Hula HP
EBPV brake
Float seat, do you mean needle seat? When I took my K301's carb apart, there was nothing you needed a pair of pliers for. The pin for the float just pops out with a bit of pressure from a pin, the needle just should fall out, and the needle seat should have a hex on it to fit a socket over. I believe you need a thin wall socket though.
__________________
- Ian
Just sent it to illustrate that some float needle seats unscrew and some have to be pulled. Didn't know if you had the Kohler carb or Walbro.
__________________
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
Hula HP
EBPV brake
