Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #31 (permalink)
Old 06-25-2009, 02:20 AM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
The old two screwdrivers and a pair of needle nose trick not strong enough for the Kohler springs?
I don't understand why there would be a diode in the ignition system. My K301 on my Cub Cadet doesn't have a diode anywhere. Although Diodes do have a slight voltage drop, it could have been used as a suedo-resistor of sorts. Although I'm quite sure all the normal Kohler coils are 12v/Internal Resistor units.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #32 (permalink)
Old 06-25-2009, 01:40 PM
ford2go's Avatar
ford2go ford2go is offline
ford2go has a good reputation on FTE. ford2go has a good reputation on FTE. ford2go has a good reputation on FTE.
If I was as handy as most of you guys, I wouldn't need special tools -- but, I'm not.
As for the diode, I mentioned earlier that I think that this was an older engine stuffed in a newer tractor. I also think that they 'patched' the engine.
Diodes are used on WH breakerless (pointless !) systems. It doesn't provide much of a drop ( 0.6 v is pretty standard), but it could limit the current somewhat.
I don't see any need for it, and it may be hindering the ignition slightly, so I'm going to get rid of it. It's not the source of my problems -- I have jumpered it out while testing.
__________________
ford2go (hj)
Wish I had -- F150 I6 5 speed
Have E350 RV
  #33 (permalink)
Old 06-25-2009, 02:38 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
Are you 100% positive it's a diode and not a capacitor? If a cap fails shorted, it'll take away your spark.
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #34 (permalink)
Old 06-26-2009, 01:41 AM
ford2go's Avatar
No, there's a diode in series between the +12 and the + coil lead.
I don't actually know where it is, I just found it with my ohm meter.
My Kohler manual shows that they use them for the solid state ignitions.
__________________
ford2go (hj)
Have E350 RV
  #35 (permalink)
Old 06-26-2009, 10:00 AM
GlennFordx4's Avatar
GlennFordx4 GlennFordx4 is offline
Who The Hell Are You
GlennFordx4 is gaining momentum as a positive member of FTE.
Ok I am going to throw this out there,have you checked for water in your fuel,looking at the color of your exhaust valve it looks like water has been hitting it when it is very hot(leaves white ash deposits) and will cause the problems you are having.All it takes is a little bit of water to cause problems and if there are other issues it will just make it worse,this new gas has been giving me tons of problems with water which it absorbs on small engine carbs and fuel systems this season.
__________________
Glenn
86 F150 302 efi aod with shift kit slamming stereo two tone blue and rust
93 EB bronco 5.8 all stock for now
04 jeep liberty wifes car
84 f 250HD 4x4 supercab 460 4 speed (Barney) HE'S back
Tags
automatic , coil , compression , gap , k301 , kohler , leak , plug , release , spark , testing , wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
