Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 05-20-2009, 05:52 PM
Randy2631 Randy2631 is offline
Randy2631 is starting off with a positive reputation.
No Power
Im lost so i hope someone can help me. I have a 1986 F150 with a 4.9L six. i was changing my starter solenoid monday and after i put it on, nothing worked. it acted like there was no battery. went back to autozone and found out they gave me the wrong one. i got the right one and put it on but still nothing. i tried changing both battery cables and still nothing.
im sure its blown fuse or a short but i dont know where it could be. all the fuses in the fuse box look fine.
  #2 (permalink)
Old 05-20-2009, 07:29 PM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
Check to see if you have 12V at the battery. Then at the solenoid. See if you disconected your "Power" wire to your dash. If that is gone you cant crank the engine, use the radio or do anything electrical. The wire usualy runs from either the cable clamp or a spade off the hot side of the solenoid.
Hope this helps.
  #3 (permalink)
Old 05-20-2009, 07:38 PM
thanks ill go check that now. i have 12V at the battery for sure cause i checked that earlier.
another weird thing is that if my brother jumps the terminals on the starter solenoid and i turn the key, the starter will turn the engine over but it doesnt run. when he takes off the screwdriver it dies
  #4 (permalink)
Old 05-20-2009, 11:21 PM
Thats normal. I start engines under the hood that way frequently. One used to be able to buy a hand held switch that hooked in to do this.
Is this PU a carb model or fuel injected?
Check for loose wires, unpluged harnesses and other stuff. If it is fuel injected it may run rough for several weeks as the computer will lose its memory and needc to re-program itself.
  #5 (permalink)
Old 05-20-2009, 11:32 PM
its got a carb. its got a feed back one barrel. i want to switch it to a non feedback one eventually
i tried chaseing the smaller wires from my relay but its a real rats nest of wireing. i traced one wire that was spliced into five others. it looks like it was one ground that was the ground wire for five sensors.
its gonna be a real pain to trace this problem
  #6 (permalink)
Old 05-24-2009, 01:07 PM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
There should be 3 or 4 fusible linked wires on the hot side (battery cable side) of your solenoid. If I remember right, the large yellow wire is the one that would kill everything in the cab, including the ignition switch. Should have a small red with blue stripe wire that engages the solenoid. I forget the other (main) colors of the other wires that should be on the battery side of the solenoid. Sounds like someone really hacked up your wiring harness, which sucks. Good luck, hope you get it figured out.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #7 (permalink)
Old 07-02-2009, 11:56 PM
Fixed!
Thanks to everyone for your help. it turned out to be a combination of things. i had the wires to the solenoid on the wrong post but switching to the right one didnt fix it because the solenoid posts were stripped. i replaced the solenoid and finally switched the wires to the right post and when i turned the key it cranked....and kept cranking when i pulled the key out. turns out the new solenoid i bought was bad. after i got another new solenoid and got the wires on the right post everything worked and the engine ran great.
  #8 (permalink)
Old 07-03-2009, 10:29 AM
Harte3 Harte3 is offline
Harte3 is starting off with a positive reputation.
It may be just me but over the years I have had several starter solenoids/relays that were bad when new out of the box. Same thing with rebuilt starters.
__________________
1983 F150 300 I6, Comp Cam 260h and lifter kit, Port/Polished head, Offy DP Manifold, Holley 4160/1848-1 465 cfm, EFI Exhaust manifolds, Walker Y Pipe to 3-Way Cat, generic Turbo Muffler, Recurved DSII, Mallory HyFire 6a & ACCEL Super Stock Coil, Taylor Spiro Pro Wires, EFI plugs.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
