1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2004 F250 w/ leveling kit: Can i run 35/12.50 18" rims?
Old 05-20-2009, 08:06 AM
hallr1158's Avatar
hallr1158
hallr1158 is offline
I apologize for the same old question... but can I run 35/12.50 on an 18 inch rim with just a leveling kit installed? I am willing to cut the plastic/front splash gaurd if necessary.
Old 05-20-2009, 08:12 AM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
...Thread Moved to the Super Duty And Heavy Duty forum...
Welcome to FTE!
Old 05-20-2009, 08:15 AM
ffadragon's Avatar
ffadragon
ffadragon is offline
Absolutley.
I have a 04 F250 with 315's with a leveling kit.
All I had to do was cut 1" off of the lower air valance on each side you cant even tell I cut it. Took about 2 minues with a saw zaw.
I am guessing your rims have a 4.5 in backspacing right???
That is a must, or you tires will hit the leaf springs.
Old 05-20-2009, 08:50 AM
hallr1158's Avatar
hallr1158
I currently have my stock rims, but plan on buying new ones. If you would, can you set me straight on the combination of the 35's with the correct rim size so I dont screw up?
Thanks
Old 05-20-2009, 09:10 AM
ffadragon's Avatar
ffadragon
Your rims need to be either 9 in wide or 10 in wide with 4.5 on backspacing.
As far as height of rim that is up to you.
I am running 16X10's bceause I like a little more sidewall to my tires.
Just remember if you increase to a 17 or 18 in rim you add about $25 per tire per inch you go up. 35X18' are a lot more expensive than 35X16"
Also make sure you are getting the 8X170 Bolt pattern. That is what our truck run.
Old 05-20-2009, 09:36 AM
hallr1158's Avatar
hallr1158
Any pictures of your tires/wheels on your truck?
Old 05-20-2009, 01:55 PM
mwsF250's Avatar
mwsF250
mwsF250 is offline
Keep in mind that different brands/model tires of the same rated size are not actually the same size. Some are bigger than rated, some are smaller.
My BFG TA K/O's in 315/75-16 did not require any trimming with only 2" lift as they are slightly under a true 35".
Old 05-20-2009, 02:35 PM
ffadragon's Avatar
ffadragon
MWS make a good point, also even in the 250 class different trucks have lighter or heavier springs in front, which may make a little differrence. Also each lelveling kit raises the front just a little different.
Any way you look at it you can do what you want with little to no modifications.
Old 05-25-2009, 03:42 PM
hallr1158's Avatar
hallr1158
Thanks again. I believe I have found what I want but there may be a slight issue.
Tires: Pro Comp 35 12.50 R17
Rims: Xtreem Allows Series 7005. They are 17x9, 8 on 170 but 4.75 on backspacing
Will this .2 in variance in the backspacing kill the deal?
Thanks again mwsf220 and ffadragon for your help.
Old 05-26-2009, 08:36 PM
high ho silver's Avatar
high ho silver
high ho silver is offline
With the 35 inch tall tire and only a leveling kit, you will most likely get some rubbing on the plastic inner fender liner, and maybe on flex/turns, the front lower bumper. With the 4.75 backspacing, you will most likely rub the leafs on full lock turning. Both can be overcome with a few minor alterations to the truck. Good luck!
Old 05-26-2009, 09:38 PM
mstiles19's Avatar
mstiles19
mstiles19 is offline
on my truck they rub at full lock but do not hit the plastic part of the bumper.
what minor alteration can i do to stop the tires from rubbing?
Old 05-28-2009, 09:35 PM
high ho silver
To stop them from rubbing the leaf springs, I welded a small nut to the bump stops at the steering knuckles.
Old 05-29-2009, 12:43 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
9" wide rim you'll want 4.5" backspacing, 10" you'll want 5" backspacing. You could go up to 1/2" more backspacing than that, but you'll be close to the leaf springs then. I have 35x12.50x18s on Diamo 17 Karats which are 10" wide with 5.06" backspacing, the tread is about 1/4" outside the fender and 3/4" from the springs at full lock. The further in you tuck them, the less fender and bumper clearance issues you'll have.
That backspacing on a 9" wheel should be about ideal.
Old 05-29-2009, 01:18 PM
mstiles19's Avatar
mstiles19
ok so i have another question i was going to adjust the bump stops but i realized that this would hurt my turning when i put my stock size tires on that i use when ever i have to tow long distances. what would you think about putting on 1/4 in wheel spacers?
Old 05-29-2009, 02:27 PM
cartmanea's Avatar
cartmanea
You can drill and tap your bump stops and screw a bolt in to make them adjustable.
Quick Reply: 2004 F250 w/ leveling kit: Can i run 35/12.50 18" rims?
